Hi everyone
Little while ago i got some cortina uprights given to me from my uncle which he had spare from his locost he built a few years ago.
I have now got to wondering weather the front suspension based on the Ron Champion book (which my uncle built) is the same as the Haynes roadster
which i am building?
Soooo, can anyone tell me if I can use the Cortina Uprights on the Haynes roadster?
No, without changing the design..
OK. so whats the difference between the two?
the ron champion book was designed for cortina uprights, the hayn es roadster was designed for sierra uprights,
Geometry is quite different
I have not yet made up my wishbones and was planning to fit the suspension brackets this weekend.
Is it possible for me to adapt the design in anyway?
If so what is required and what are the implications?
They have different geometry.
You might get some other answers over on the Haynes forum. The author of the book is a member and posts regularly
If you sold the Cotina uprights and bought Sierra you'd definitely make a profit, even after buying mushroom adapters.
Thanks will post there.
Are the differences not just the wishbone length then?
Yes.
After doing a search for cortina uprights on the haynes forum i found this..... (for future reference)
http://www.haynes.co.uk/forums/showthread.php?t=2487&highlight=cortina+uprights
As I think you've surmised the top wishbone will definately be different. (Shorter if you use Cortina).
As for the bottom wishbone, it'll need to be different only by the amount the distance between bottom BJ centre and hub face is different between
uprights.
So, if the distance between bottom BJ centre and hub face is greater on Cortina than Sierra (as I suspect) then the wishbones will need to be shorter
by that amount.
If the Sierra BJ centre to hub is greater than Cortina then the wishbone will need to be longer.
Having said all that it looks like you can get away with only changing the top wishbone.
HTH,
James
