Kit delivered tomorrow!!!!
Poorscousertommy - 9/12/11 at 06:58 PM
As above, credit to the boys at MK - 1 week from order to delivery, Indy R deluxe kit, full donor pack and quick rack
Now running round like a maniac trying to get the garage prepped... Question, what do you think I am best using to keep the chassis off the ground ? Currently torn between trestles (B&Q sawhorse) or axle stands??
Urgent guidance appreciated!
designer - 9/12/11 at 07:17 PM
Strong trestles, axles stands are too low.
big-vee-twin - 9/12/11 at 07:26 PM
axle stands are fine
loggyboy - 9/12/11 at 07:52 PM
Aframes will make it alot easier, I wouldnt wanted to have done all the drilling and riveting whilst bent or leaning over:
Axel stands may work, but make note of the topgear caterham build episode to see what can go wrong!!
http://www.youtube.com/watch?feature=player_detailpage&v=l5hrFR2N29k#t=383s
[Edited on 9/12/11 by loggyboy]
iank - 9/12/11 at 08:10 PM
Decent strong sawhorses are best (IMO) at the early stages of a build. Be careful of the plastic ones as while they can take the rated load statically if you get any twist (by pushing the chassis too hard) they can fail.
Something like these:
http://woodworking.about.com/od/shopequipmentsupplies/ss/woodSawhorses.htm
Bit of carpet on the top (if it's powdercoated) will protect from scratches.
mcerd1 - 9/12/11 at 08:26 PM
mine lived on some axle stands to start with, but then I built some steel trestles out of angle/box section
I made a narrow one for the front and a wide one for the rear, then covered the tops in some rubber I got for nowt
Coopz - 9/12/11 at 08:56 PM
Good luck with the build! I hope you have rearranged your diary this weekend you wont be able to keep your hands off her I used an Old school table very sturdy, helped that I worked in a school and saved it from the skip! but otherwise I would have used trestles better height for your back.
AndyRead - 9/12/11 at 09:33 PM
I built mine on a couple of black & decker work mates!
Poorscousertommy - 9/12/11 at 10:06 PM
Thanks folks, appreciate it - glad it can be done the 'locostbuilders way'
I'm all excited now, looks like the mrs has inherited Christmas shopping duty!
snakebelly - 9/12/11 at 10:14 PM
wooden trestles on wheels, cheap enough to make
https://picasaweb.google.com/111529572187631903852/GTABodyFitting#5633561945256035106
https://picasaweb.google.com/111529572187631903852/GTAChassisTrestles#
[Edited on 9/12/11 by snakebelly]
daniel mason - 9/12/11 at 10:51 PM
Get it on axle stands, and get wishbones, shocks, springs. Uprights, and hubs. And get it on it's wheels asap. At least then you can push it outside and work on it
daviep - 9/12/11 at 11:28 PM
Kitchen stools worked for me for quite a while when I needed my trestles for something eles
keith777 - 10/12/11 at 01:20 AM
Try your local hire centre for some cheap 'H'frames adjustable heights, whereabouts in l'pool are you ?
Cheers Keith.
wombat - 10/12/11 at 07:56 AM
Mines on an old wardrobe at the moment !
Poorscousertommy - 10/12/11 at 08:14 AM
Hi Keith - we've spoke on here before! I'm in halewood mate, can't be more than a mile from you!
Chassis turns up at 1, so gonna have to get a move on, there's no way my new baby is sittin on the floor
lewis - 10/12/11 at 08:20 AM
Dont forget pics
Hellfire - 10/12/11 at 10:54 AM
We used an environmentally friendly option... Six stacked milk crates - two pair on each rear corner and one pair in the centre at the front. They easily take the weight and you can reduce them in height once the car starts getting heavier (to make it easier to jack to the floor) and when you've finished with them completely, just give em back to the milkman.
Phil
lotusmadandy - 10/12/11 at 10:59 AM
I put my Indy on tressles to start with but then
dropped it down onto axle stands.tbh the axle
stands would have done,cos it was a rolling chassis
in under a week.
Andy.
MikeR - 10/12/11 at 11:04 AM
Be careful that you make sure you can get the car off the tresles. I've heard of quite a few people building the car up and then realising you've got a heavy car 3 foot in the air with no way of lowering it.
(plenty of people on here have engine cranes and we're a friendly bunch so often will help for a drink of tea and choccy biscuit).
Thurbs - 10/12/11 at 11:59 AM
A strong build table on wheels made my build possible in a single garage, made out of 1" box section.
Maybe not a true locost option bu only cost me 50 quid for the steel some old castor wheels and and hour with the welder made life a whole lot easier.
Only drawback needed some strong mates to get it down !!
p.s some pics on my blog if any help.
[Edited on 10/12/11 by Thurbs]
loggyboy - 10/12/11 at 03:51 PM
My stands were proper locost!, £10 from ebay!
They're £100 new from westfield!
MikeR - 10/12/11 at 10:31 PM
ps forgot to add, i got two cheap B&Q workmates. in 2000 they had them on offer for £10 each. I threw one away when i burnt the top, the other i repaired and still have it. Having two workmates does prove very handy when doing DIY type jobs.
Neville Jones - 19/12/11 at 12:51 PM
Maybe a good tape measure, an accurate level, and a couple of plumb bobs and string lines would be a good start, just to check the accuracy of what you are dealing with before setting out on your mystery tour.
I believe a word from Matt at Procomp may help.
Nev.
blakep82 - 19/12/11 at 12:57 PM
because my chassis is quite heavy, I just had some blocks of wood under mine til i got all the wheels and suspension on.
don't need anything fancy 4 bits of 6" square fence post did me!
ReMan - 19/12/11 at 02:40 PM
Nev.
Surely it does not need to be dead sqare and level just to build it?
The setting up can be done once it''s complete and rolling
loggyboy - 19/12/11 at 02:42 PM
Hes talking about the car. There have been comments made by some who found the MKs geometry and build to be a little out.
Probably best to ignore most though.
Neville Jones - 20/12/11 at 01:53 PM
You ignore the accuracy of the build of the chassis at your own peril. Very few can be termed 'straight and true', and even fewer symmetrical.
Knowing what you have to start with can save a multitude of worries later on.
Nev.
wilkingj - 5/1/12 at 09:01 PM
Ditto... Was just fun getting it off them! The chassis gets heavier as you keep adding bits one.
Used engine crane and did it in several staged moves.
A good working height is very desirable, as you spend a lot of time working on the car, and last thing you want is an aching back / legs / arms / neck etc etc. It all helps to keep the morale up!
You will have highs and lows during the build.
Just keep at it. Little and often was the key for me.
Finally DONT FORGET... PLENTY of PICTURES for us all to see and comment on.
You will get loads of help form the forum, so let us see what you are doing, we might be able to save you some time and grief.
