Towing eye
steve m - 16/9/12 at 08:27 AM
I want to put a towing eye, or similar on the front of my 7, what have others done?
i was thinking more like the exhaust clamp u bend with the two threaded ends?
AntonUK - 16/9/12 at 09:53 AM
thats what we used on a mighty mini... worked fine getting it dragged from the kitty litter at brands
Confused but excited. - 16/9/12 at 10:40 AM
Don't forget to reinforce the chassis member with welded in tubes where you intend to put the bolts through.
macc man - 16/9/12 at 10:49 AM
It might be better to weld it to the chassis. Drilling the box section will weaken it.
RichardK - 16/9/12 at 12:30 PM
I'd use a couple 5mm pieces of flat with a couple of hole in each for the exhaust U clamp to go through with a couple of nuts on each leg and sandwich the chassis.
Rich
lsdweb - 16/9/12 at 05:59 PM
Not a '7' but I have used a spare piece of tie down strap, wrapped around a tube, with a couple of bolts through the strap. I did the same when I had my Locost and it worked fine (and got used a lot!)
It's not that clear in this photo - will try and take a better one.
Regards
Wyn
lsdweb - 16/9/12 at 06:23 PM
steve m - 16/9/12 at 07:44 PM
Thanks Guys, a couple of good solutions
Angel Acevedo - 25/9/12 at 03:00 AM
Tie Strap Solution is Genius!!
Goes very well with the Lightweight Credo...
Hand stitching may remove a couple of ounces more...
lsdweb - 25/9/12 at 06:40 AM
I may stitch it in future! This was a quick fix to get a strap on it. Ideally, I'd have done it before the towing strut had been glued and bolted into the front crash box!
Wyn
ken555 - 25/9/12 at 04:53 PM
Peugeot 406 rear seatbelt with the catch removed, bolted to subframe.
Then held to body work with a loop of velcro, to keep it off ground.
[Edited on 25-9-12 by ken555]
JonT - 25/9/12 at 06:36 PM
We used a towing strap bolted to one of the suspension pick up points (so should be strong enough)...
See here for an example
procomp - 25/9/12 at 06:55 PM
Hi
As above with the seat belt or one of the proper made for the jobs from TRS Willians Etc etc. On a locost for racing it is usually attached to the front lower wishbone bolt and neatly tucked in the nose cone. Also for racing it has to have a 60mm opening / loop.
[img] Description
[/img]
Cheers Matt
steve m - 25/9/12 at 07:25 PM
These straps are cool, so may go off to the breakers tomorrow
