Lotus mkiv chassis-pics?
tigris - 30/3/07 at 10:59 PM
All I can find out about this is that it was chapmans first spaceframe, and that the whole thing weighed 55 lbs. Tubing used was <1" diameter.
Anybody have information on this? I'm sure it is similar to the 7 but just wondered if there are pictures floating around.
tigris - 30/3/07 at 11:16 PM
Thats vi or 6 , sorry my roman's a little rusty
Confused but excited. - 30/3/07 at 11:18 PM
Don't know if it's still there, but if you do a Google (Images) for 'Lotus 7', there used to be a set of drawings that may be of use.
Macbeast - 31/3/07 at 05:56 AM
There is this but not sure its a Vl as they should have rounded rear
[img]upload/Chapman with chassis jpg.jpg[/img]
[img]upload/hornsey4.jpg[/img]
[Edited on 31/3/07 by Macbeast]
[img]/upload/Chapman with chassis jpg.jpg[/img]
Sod it...I've spent 2 hours trying to insert these pics. They're in my photo archive. Why does insert not work for me??
Yes I've looked at all the posts, done search etc
gazza285 - 31/3/07 at 08:08 AM
Image deleted by owner
gy351100 - 31/3/07 at 09:28 AM
Hi
The Lotus iv was an Austin Seven frame and Ford 1172 engine built for trials in 1952
Catpuss - 31/3/07 at 10:43 AM
Its becuase the sample url on the upload pages is wrong. It just needs a tweak to the text on the upload page.
You need to use http://locostbuilders.co.uk/upload/....
[Edited on 31/3/07 by Catpuss]
tigris - 31/3/07 at 12:00 PM
great pics, thank much,
looks like alot of that tubing is 3/4 round
Macbeast - 31/3/07 at 09:55 PM
Only references I can find are "The tubing we used was brand-new welded furniture tube..."
and
"The MKVl chassis was to be a multi-tubular fully stressed space frame with the main body panels actually riveted to the frame's small diameter tubes , of both round and square sections, thus providing extreme rigidity and strength yet keeping the total weight to the absolute minimum"
Crombach- " Colin Chapman the Man and His Cars"
t.j. - 1/4/07 at 06:18 AM
I will look in my archive
I'm sure i have some piccies.
cs3tcr - 1/4/07 at 05:05 PM
Those two pics posted were of the Eleven Series 1 frame. The 6's used 1 7/8" diameter lower tubes, while the upper ones were either 1" round or 1" square.
If you can wait till tomorrow, i can scan a bunch of pics of the 6 frame and send them to you.
Or if you want i might be able to find some Eleven chassis blueprints for you.
Rod
[Edited on 1/4/07 by cs3tcr]
stevebubs - 1/4/07 at 09:06 PM
The car in the foreground shows a nice early use of cycle wings instead of clamshells, though....
Macbeast - 1/4/07 at 09:47 PM
Try again...
This is supposed to be Lotus11 S1
I guess the chassis Chapman is holding could be Lotus 11, but the car in the foreground looks very much like a Vl
As I said, I could be wrong
[Edited on 1/4/07 by Macbeast]
cs3tcr - 2/4/07 at 05:47 AM
The chassis in the forground was a Series 1 Super Seven, Climax powered. The 6 had a divided front axle, where as the Sevens have the lower wishbone with top links and a sway bar.
The photo of Chunky holding the frame was a publicity photo for the "new" Eleven.
Why do i know this, i spent way too much time in my youth reading about Lotus.
There was a company making 6 clones, i cant remember their site, but they were near duplicates of the original cars.
~Rod
t.j. - 2/4/07 at 06:46 AM
First what did you ment with MKIV?
the lotus 7 mk IV?
or some older stuff as the:
1948 Mark 1
1949 Mark 2
1951 Mark 3
1953 Mark 3B
1954 Mark 4
Mark 5 (never produced)
1954 Mark 6
Mark 8,9,10 (mark 6 look-a-like)
1956 Eleven
1957 Eleven series 2
1957 Lotus 7 series 1
1960 Lotus 7 series 2
1968 Lotus 7 series 3
1970 Lotus 7 series 4
1973 Caterham 7 series 3
etc
In my photo archive are some pictures of the lotus 6. (info to others)
I have more lecture, Also the caterham chassis tru the years. But not much before the seven.
Grtz
[Edited on 2/4/07 by t.j.]
Macbeast - 2/4/07 at 10:53 AM
He said the first space frame so it must be the Lotus Mark six
added:
Sorry cs3tcr, when I said "try again" I meant me uploading pics, not doubting you
[Edited on 2/4/07 by Macbeast]
mlgates - 11/4/07 at 04:45 PM
mlgates - 11/4/07 at 04:51 PM
mlgates - 11/4/07 at 04:53 PM
