Thought it was time I posted some pics of my creativity!
Hadn't realised you were having front struts. Excellent work.
How did you get the positions for the strut tops, off a shell?
John
looks amazing!
Neat.
That looks good
John
Nice work
that looks like a real good peice of work.. impressed - while its at this stage i would defo add some roll bar struts - that isnt strong enough.. have any pics of one finished?
looks amazing, top work!
Someone on another forum commented that they thought the arches wouldn't allow for clearance of the wheels and it kinda made me think, and then
you know it would have eaten away at me....
...so I got home from church "just got to go into the garage for 20 minutes, babe...." didn't stop to wait for an answer
Am I as happy as a pig in his own excrement right now...? What do you think?
where abouts does the engine go is it behind the struts i cannot see the area to fit it thanks william
So i see know so it will not be the s14 engine then what engine will you use
As promised, some pictures of the jig
.jpg)
I then "dropped" the location of the top mounts down by 100mm on each side.
The top mounts had previously been made using 25mm angle, of all things!
Very interesting. Looked like it might have been a bit tricky to get it out of the shell, though?
What's the rationale for doing the spaceframe? Obviously it's going to make it easier to mount the mid engine, but are there any other particular advantages? I presume you will be using a lot of the original body (or glass fibre versions) so do you think there will be much of a weight saving?
This is all very interesting stuff
John
John
Oh, and in terms of body panels, my iuntention is to build the surface using no compound curves. I can then easily make a symetrical plug to produce a very thin body skin, which I will strengthen by filling with expanding foam.
So presumably it isn't going to look like an S14 when it's finished? I had thought maybe that was the original idea, especially as you have retained the front struts?
John
Did more welding tonight - if I'm honest, it's getting a bit boring there's so much! Just when you think your on top of it, you look
at it from another angle and unveil more
Still, not too much more now. Should finish it tomorrow evening. Then I can get onto the serious issue of making my chassis a rolling chassis, the
first step of which is to fit the steering rack mounting. I've made so much for that car, that I feel like I ought to make this, but it's
not the simplest thing in the world, and as I have one there already from the donor....
Once it's on four wheels, there's the challenge of the rear shocker / strut units. Unlike the front McPhersons, these don't form part
of the geometry, and so the alignment of them is not as critical. My current thinking is to look at using a push rod and bell crank to allow them to
be used horizontally - lowering their CofG and putting their weight further forward. It would also preserve what lines of the car are there are such,
and will require less "extra" chassis to be put in to enable them to be fitted.
My old S14 shell went toda - which was really quite sad
But then I also did this, which mad e me happy!
Well, it fits in the garage - but only just
I'll not be doing anything that requires a wheel taking off....
Very interesting: COOLText
