7"plug in shaft Diff for 7" LSD Diff
westindy - 8/3/11 at 06:58 PM
Hi, I want to replace my existing std 7"diff with plug in shafts with a LSD ( BOLT ON FLANGES ). How do I do this and keep my Drum Brakes. I am told you can replace the plug in shafts with flange CV's but my shafts are 22 spline and the Cv's available are 25 spline.
I have read a couple of articles see link but its not that easy !
http://www.carbuilders.info/pages/Sierra_Diffs
Anybody done it and can tell me how to?
Regards, Paul
snapper - 8/3/11 at 08:26 PM
You need to make a hybrid shaft using Desiel push in shafts.
You take the tripod uj off and replace with lobro CV joint.
Sierra owners club have photos and info or u2u me and I will see if I can find the info and email you.
A mate of mine has put lobro flanges in a push in diff, needs some work to get the input bearings to the right point or the stubs jam the planet gears shaft.
Pezza - 8/3/11 at 08:40 PM
Same as above, I just swapped the tripod joints for lobros and it bolted straight up to the LSD.
coozer - 9/3/11 at 11:43 AM
I did just as your intended and simply axed the caliper mounts off the bearing carriers.
Job done.
westindy - 9/3/11 at 06:24 PM
Snapper u have u2u - thanks for your help!
Cheers, Paul
ashg - 9/3/11 at 06:37 PM
Job done.
love it. was thinking along the same lines when my lsd goes in. the drums work well and i cant be bothered to modify my rear uprights to run discs.
