Hi,
I dont know how many GT-R builders there are out there but hopefully someone will have an idea on how to fit the sierra handbrake cable. If I didnt
have the engine the cable would fit perfectly, however the engine will be fitted at some point.
The problem is that the left cable no matter where I route it will rub against the engine gearbox.
If anyone has the answer please let me know.
Dave
Have you already tried MK Engineering?
No not yet. I thought I would try and see if there were any other builders out there as we seem to be a bit scarce on the ground!!
MK have a GT-2 in their workshop so best ask them.
I will give them a call tommorow.
Good luck with it... how far how you off finishing, I'm sure I'm not the only
one asking
Still a long way to go. Most of the panelling is done and the brake lines and suspension are fitted. I was hopeing to drop the engine in for a trial fit when my new sump arrives but I will wait until I can get the handbrake cable problem resolved.
How you doing ?
I can take a few pics of my GT1 handbrake set up if you wish, would be pretty much the same i guess, rear engined with engine too negotiate ? Trouble
is a few bits have move a little in the shunt.
That would be a great help. Sorry to hear about the crash it looked pretty horific, glad you are ok.
Are you rebuilding the original chassis or maybee a GT-R
