Output flange to prop on Blade
the_fbi - 2/4/06 at 09:55 AM
Had a quick look at the gearbox adaptor / prop flange yesterday and it appears that the prop flange may actually be a bit close to the waterpump housing.
Without a prop its hard to be certain but has anybody else had issues with the generic adaptors which are floating around eBay?
Looks like I may need to reduce the diameter of the flange
Gav - 2/4/06 at 12:53 PM
My blade engine is a 97 RRV and the adaptor i have fits fine, i have offered up the sierra prop flange to it so i could get a better idea of the prop angle and nothing seemed to big to fit.
Also he adaptor i have is smaller than the sierra prop flange so im assuming when i come to order my prop ill be able to specify the PCD and flange diameter.
[Edited on 2/4/06 by Gav]
ChrisGamlin - 2/4/06 at 03:36 PM
Yor flange diameter is dictated by the prop flange diameter / bolt pattern, which are generally Ford pattern. You can't turn it down without sourcing a different prop flange, so as long as youve got one that fits the standard Ford prop flange pattern, you should be fine.
mad-butcher - 2/4/06 at 06:54 PM
I am led to believe the sliding section end of a BEC prop is off a reliant which might be smaller diameter
Tony
ChrisGamlin - 2/4/06 at 07:32 PM
Im not sure it matters if its sliding or not, the back need to mate to the Ford diff so that size is fixed, and I thought the for the majority of supplied output shaft flanges, the front was also a Ford fitment (could be Reliant too I guess).
