So how much does it cost to tax a bec.
It might be different if a kit is registered on a brand new plate (?) but most if not all fall into the same bands as any other pre 2001 car, so its considered the same as any other 1000cc car, which I think last year was ~£110 for a year.
it's all on emmisions now
info here linky
ALL cars registered after March 23rd 2006 with more than 225g/km £210 per year
[Edited on 11/5/06 by DaveFJ]
but g/km of co2 isnt tested at sva is it so it cant be emissions related.
it's taken from the tables laid down by VOSA. if your car isn't listed then I beleive you come under the visible test category (same as cars
registered before March 2001) so £110 up to 1549cc or £175 over 1549cc
how is that fair when a smoky old banger costs £50 a year less to tax than my 3 year old tin top running unleaded and a cat ?
I know that a car engined kit car is taxed based on the rating for the engine donor... however there is nothing to say what a BEC should pay - I have
actually contacted VOSA about all this so will let you know when/if they reply!
my blade is £110 just paid it last week on the web.
had an answer from DVLA - they said f*ck knows ask VOSA....
had an answer from VOSA - they said f*ck knows ask DVLA (but maybe it is checked at SVA)..........
so answer is 'f*ck knows'
ain't they great!
to get an accurate co2/km value you would have to put the car on a rolling road and run in though a set test procedure (ie to simulate road driving)
whilst testing emissions. the tests manufacturers have to do is very long and it would be impractical to do that for every car.
you cant even take the manufacturers numbers for cecs as many engines are found in different models all of which have different ratings and as weight
has a massive effect, kit cars should be much more efficient than the donor.
