For anyone that thinks bike engines have no torque take a look at the picture below
Twisted Axle
This is what a Kawasaki ZX10 (approx 137bhp & 79ft/lbs) will do to a 30mm dia 6mm thick chunk of steel if you get a bit over aggressive with the
take offs! Up until last week this was one of my axles on which the sprocket drive is located, I will admit to giving it quite a bit of stick recently
but when it finally broke I was being gentle with it. If you look at the keyway you will see it has twisted along its length, fortunately I don't
need the keyway so its replacement is of uniform thickness & section & hence substantially stronger.
[Edited on 13/6/06 by russbost]
i see no pic
[Edited on 14/6/06 by Mr G]
Imagine what Zetec would do then!
You copy and pasted the url of the picture from the address bar at the top - That won't work - If you look at the bottom there is part of the
correct url with image tages either side of it (Where it says Forum Code )
You then need to add http://www.locostbuilders.co.uk to the start of the address after the first [img]
i.e
[ i m g]http://www.locostbuilders.co.uk/upload/twisted axle.JPG[/i m g]
I've put a space between the letters in [IMG] otherwise it would display the picture not show you an example of the url you need to copy and
paste!!
HTH
G
Thanx Mr G now sorted & I've learned something new!
Originally posted by russbost
Thanx Mr G now sorted & I've learned something new!![]()
Bike engines may have low torque at the crank, but they have something a car engine does not..
Primary Reduction.
A very effective torque multiplier
...and high revs too, which means you can further gear it down and multiply it up
So that's what a gearbox does
I think you know what I mean
Torque multiplication should be on the GCSE Maths syllabus!
