Blade Oil Pressure Thread ???
Avoneer - 19/7/06 at 11:35 PM
As I'll be using my DigiDash2, does anyone know the thread size in the block next to the clutch that the standard oil pressure sensor bolts in?
I'm gonna bolt in the ETB supplied 1/8th NPT oil temp sender in there, but looks like I'll need an adaptor.
I have an extra hole in my sump for the ETB supplied 1/8th NPT oil pressure switch.
Pat...
Gav - 20/7/06 at 09:07 AM
Hi Pat,
I think youll find that you carnt bolt it straight on because of clearance anyway, evan if it was the same thread, iirc its BSP.
What i did is get a extender and Tee Piece from LMA Group for about £15, you can then put all your wotsits on that.
http://www.lma-group.com/motorsport/Products/Gauge_Fitting_Parts/gauge_fitting_parts.html
look for the product code
LMA095 should be 1/8th BSP male extender with 1/8 NPT tee piece, make sure you buy the additional blanking screw if you dont need both ports on the tee.
