Hi!
My next project has now started- Iīm going to rebuild my two seated MRide T42 turbo trike to a formula like sportscar.
The Engine is still the same Suzuki GSX 1000-R turbo bike engine with 300hp @ 1,1bar boost. The Mride "T"42 stands for Trike,
and Mride "C"42 stands for Car.
The 3-wheeler have dubble wishbones and Pushrod suspension in the front. So it will be the same at the rear. The total weight will be around 540kgs +
driver
Iīve started to make a TORSEN chaindrive differential.
Read more om my website!
www.mride.se
This is a scetch Iīve done to illustrate the Mride C42 turbo sportscar.
Sir, i salute you
i]Originally posted by Micke Fredriksson
Hi!
driver
www.mride.se
So why the move from 3 wheels to 4?
I was thinking of doing a self designed 3 wheeler next so would be interested to know your reasoning.
Looks like a tidy project
At a guess, with 300hp, a severe lack of traction from one wheel?
]Originally posted by pathfinder
Now thats looks like fun to me
will be keeping my eye this project..jpg)
Finally a post without arguing!
What an awesome looking machine!
The best of British/Swedish luck to you - if you know of any single women - er.. send em over
M
Unusual looking beast.
I love it!
Another unbelievable project Micke...
I have every belief that it'll turn out aswell as the first!
Good luck and keep us posted.
Chris.
How does the differential cover you have TIGd up seal against the ring gear plate and diff side?
Does this whole cover rotate with the differential when locked up?
Any fluid inside the diff?
Ta, Chris.
Wouldn't four wheels mean that it's a car and hence illegal to drive ? (power to weight ratio thingie they have in Sweden)
Can't be SVA'd can it ?
Hello everybody! Thanks for all the kind words!!
Yes! The reson why the redesign to a car, is just TOO MUCH POWER!!
The 300hp is just not doing any good under 200km/h.
The performance isnīt so bad as a 3-wheeler= 0-100km/h in 4,5sec, 0-200km/h in just under 10sec. And brakes 1,1G and corners like a locost seven. So
Iīm not disappointed at all- It is the most fun vehicle I have ever driven. But itīs just SO frustrating to know that I can use twise the power from
100km/h without sliding and burning rubber, if I just had more grip..
I have terrible fast friends that is awefully close to leave me behind
I just canīt let that happen!!
So, more wheels= More traction,= More Acc, Faster cornering and better brakes!!
It will be better in every way!!
The Torsen diff is taken from a -92 Audi V8 who is the only audi car with Torsen in the rear diff "I think". I TIG welded together the diff
"housing" in ALU. The housing will be bolted with 3 M6 screws in the side flangs. I will seal the housing with a oil resistent silicone.
Yes, the whole thing is rotating the same speed as the chain sprocket.
I will fill the diff with grease as a lubricant. Hopefully that will work fine!
I forgot to mension that the topspeed will be reduced from 290+km/h to 237km/h. There will be a huge differense to launch = before the 1:st gear-
142km/h. Now it will go 115km/h in the 1:st!! NICE!!
I will even redesign the gear shifter to a mecanic paddle shifter with a Dyna-tech shiftcut. And Alot of other things too. But I have to do the rear
suspenson first.
This is the TORSEN diff.
a bitchin project...
Bet it will be an awesome drive...
or add alot of wheight..... It will be Road legal!
I checked out your site,do you have any info on your plug creation? What type of material did you use, and what methods helped you maintain symmetry? Thanks
HI! Yes, thatīs right. I can have 15kw/100kg as a car. But I donīt see it as a problem. I just perhaps leave my rotating scilencer at home that day..or add alot of wheight..... It will be Road legal!
[Edited on 4/1/07 by Micke Fredriksson]
Here is some updates!
Scale drawings.
8mm thick aluminum.
Very nice work.
Im just wondering where you sourced those blue bearing carriers for the diff from?
excellent! i'm looking for some turn buckles for tensioning the chain for my own chain diff - where did you get your from?
James
Looks superb
one word of warning tho...
I have destroyed 8mm ally plate with a 90bhp Kart Engine (rotax twin)... (may have been 6mm now I think about it)
Keep an eye on it, as the diff will be under a lot of strain...
Looks like it will be a lot of fun when its complete..
James
Agree on this point, also there will be some lateral forces, if not just from cornering - so will need some sort of cross bracing on the plates to stop the diff moving side to side I would imagine?
James
just thought i would put this on found it while doing a search.
the blue bearing carriers can be found on
http://www.bearingboys.co.uk/ourshop/cat_31087-4-BOLT-HOLE-FLANGE-BEARING.html
hope this helps
That does. Thanks
hope this helps
Time for some new picts!!
Take a look at me website: www.mride.se
Man you do some lovely work...
Cant help thinking the bike frame is probably no longer needed and you could shed some weight tho...
Still want one mind
Still want one mind
Fair do's, I will reserve judgement until its had a few hard drives..
Just from what I know about bike frames, the torsional rigididty isnt up to much, might have been fine for one wheel on a swing arm, but I would have
thought the additonal bracing required to get it stiff enough for 4 wheels, would have been sufficient to make it dead weight..
I can see the bracing you have on the bottom rear end mount, but the top looks like its bolted to the frame, well a lump of ally welded to the
frame...
I can see why you retained it for the 3 wheeler, I just thought extending the top mount onto the chasis with some triangulation, then some good engine
mounts would have saved some weight and given the torsional rigidity you need...
with the engine mounted at 3 points, it requires far less reinforcement than you would think...
As per usual Micke, upto your usual awesome standard! Can't wait to see the videos of that one caning it around!
Have fun!
Chris.
AWESOME!
Thanks !!!
Now it is standing on itīs own wheels!! YiiHaaa!! Whereīs the summer heat?
[Edited on 18/3/07 by Micke Fredriksson]
thats just lovely...
Looks like its beggin for a rear wing tho
The Rear brakes takes shape!
Honda CBR 900rr rotors and calippers.
The Mride C42 sportscar is now totally roadlegal!! Really cool!
This is some picts from my first legal trip with some icecreame eating.
This is my new carbonfibre fenders I+ve made to the car. Really nice I think.
thats mega
holy s...t , thats fantastic, I love it!
Originally posted by chris mason
love those cycle wings, they look top class, where are they from?
how big is the car, it looks big/high/long or is it just photographic deception![]()
Chris
I'm curious about the diff cover, about how it can hold grease/oil from leaking out. Yes I know it'll be sealed, but it seems to me that as
the differential heats up, it's going to pressurize the lubricant and push it out through your gaskets... Let us know what happens.
Also glad to see you switched to 4-wheels. I couldn't help but smile when no times were given after your drag racing. I knew it was because the
lack of traction caused really slow times. Not any more.
Also, about the rear brakes, did you run through the numbers to see if they're sufficient? Yeah I know there's two of them, but there's
a lot more weight being decellerated by them than on the bike, where there's about zero weight on the rear tire under braking. Just wondering.
Lastly, about the diagonal aluminum brace on the diff... it bugs me. Either:
A. There's a lot of side force and it'll be way, way too weak.
or
B. All cornering and twisting forces are handled by the surrounding tube chassis, so it isn't needed at all.
What am I missing?
[Edited on 6/25/07 by kb58]
Originally posted by kb58
I'm curious about the diff cover, about how it can hold grease/oil from leaking out. Yes I know it'll be sealed, but it seems to me that as the differential heats up, it's going to pressurize the lubricant and push it out through your gaskets... Let us know what happens.
Also glad to see you switched to 4-wheels. I couldn't help but smile when no times were given after your drag racing. I knew it was because the lack of traction caused really slow times. Not any more.
Also, about the rear brakes, did you run through the numbers to see if they're sufficient? Yeah I know there's two of them, but there's a lot more weight being decellerated by them than on the bike, where there's about zero weight on the rear tire under braking. Just wondering.
or
What am I missing?
Ah, okay, I didn't realize your rear brakes were the bike *front* brakes. Much better!!
Hello!
Iīve published two videos from the SFRO roadtesting day. SFRO is a organisation thatīs testing your vehicle several times during the building process
to get it roadlegal!
Fun!
Visit my website to see the videos.
http://www.c42.mride.se/video.html
Fantastic achievement Micke!
Bet you can't wait to get it on the track...
I have now tested the Mride C42 sportscar in a slalom corse to see how the suspension works. Iīm really pleased with everyting I couldnīt ask for
anything better regarding to ballance and behavor.
Check out the video:
http://www.youtube.com/watch?v=Gs6AE28WNV0
