ZX12-R plumbing
the moa 2 - 11/2/07 at 10:04 AM
After having my car drenched in coolant im am hopeing none of the electrics have been ruined and am not going to fill the car up with coolant again until i am 100% that the system will work.
I have just spent an hour drawing this masterpeice which someone can happily poke fun off and maybe also return with some input.
After reading and seeing a few pics i am wondering whether the direction of the pump is correct? i thought i found it in the manual to be that but i maybe wrong. Also seen someone using an additional water bottle that the overflow goes into not sure what that is.
I have retained the original oil cooler water pipe from the water pump side to oil cooler.
Any help much appreciated
Coose - 11/2/07 at 10:13 AM
The pump should pull from the bottom of the radiator into the engine at the bottom. Yours (as far as I can tell) is the other way round?
G.Man - 11/2/07 at 11:31 AM
Coose is spot on
the moa 2 - 11/2/07 at 11:34 AM
Yeah just been reading the manuel and god knows what i was thinking i must have been backwards that day!
Can anyone comment on the plumbing lines and whether an expansion or vent tank is needed to take the overflow from the header tank.
[Edited on 11/2/07 by the moa 2]
