Hi.
Can someone tell which of the air pressure sensors go where on the hayabusa engine?
Their are two sensors, atmospheric and intake.
Which is which?
And where should the intake sensor be placed? So it measures the pressure in the airbox or connected to one of the small pipes measuring the air in
the intake manifold (after the butterfly valves)?
Can you also recommend someone for tuning the engine for SVA?
Thanks in advance!
Geoff.
So far as I remember.....
The atmospheric sensor can be put anywhere, mine's just mounted in the engine bay. The intake pressure sensor is connected via the small pipes
that run between the throttle bodies (take off the end throttle body). This sensor is the one that has two take off points, one to measure intake
pressure and the other to control the intake flap in the original airbox. There is a small one-way valve in that system also.
For sva, i used a westfield box that incorporates a cat, and set the fuel pressure to 43psi....had to mess around with the fuel pressure a lot to get
it through though - was either in at idle or at revs, hard to get both together. also left the PAIRS valve fitted. I believe you can use a power
commander but i got away with it....
[Edited on 17/3/07 by richard thomas]
i thought that unit with an inlet and an outlet was only a solenoid valve to control the airbox flap - and was no longer requiered. I didn't
realise it was a sensor as well.
0
Better start digging through the scrap pile to see if i can find it!
Thanks!
Wait a min - you might be right....let me go and have a look.
Ahh, you are correct. The one with two take off's is to operate the flap in the airbox. The atmospheric sensor is the one with two bolt holes and
is made by 'denso' on mine. The manifold pressure sensor has one bolt hole, and is fed from a pipe that attaches via a t-piece in the rubber
pipes between the two centre throttle bodies.
Sorry for the unnecessary worry there....
he will be back in 2 hours... well found it at last.. oh wait... you git.. so I didnt need it
I know, feel a bit guilty.....
Still, nobody said it would be easy...
Don't forget to feed all four tb's to the fuel pressure regulator or it'll run too rich at idle/low speed.
When i connect the intake air pressure sensor to the tubes it runs really rough. as soon as i disconnect it its a lot better... but still rough.
I think it is only connected to the small pipe for one throttle body instead of all four. I will try that tomorrow.
I tried to set the idle throttle position in dealer mode but it just stalls... but that is probably because of the MAP sensor connections being wrong.
I will fix the MAP sensor then try an set the idle position again.
Thanks for the advice! I will let you know how i get on.
Sorry, forgot to mention that when adjusting the fuel pressure, remove the vacuum pipe.
I fixed the MAP sensor connectivity and it made a massive difference. Still a bit rough with an occasional pop but i think that is due to my spark
plugs. New set ordered.
Thanks for your help!
Glad it worked !
How did you set the fuel presure ? The odd pop could still be down to that being too high and the plugs fowling, or even too low fuel pressure
although it would be difficult to start with too little too. Do the plugs look sooty after it's been running for a while ?
If you want a copy of the manual just let me know.
Can I ask what fuel pump you are running? and is it connected to the ecu?
We had awful problems with the ZX12R until we ran the fuel pump from the ECU... seems obvious, but a power source is apower source right? (ps. not my
engine)
