hi can anyone help
im trying to wire my telemetrix speedo with magnet sensor and 4 magnets, the instructions contradict what is on the website ,
cant get a reading
not sure if its wired correctly?
have you connected the 12v pull up red wire?
i had the same problem, which was discussed here
hth
tom
hi matey,
just read through your link , i have one side of sensor to earth and other wire to blue /red on speedo
dont understand what a 12v pull up is?
can you help!!
thanks
it's a red wire in the loom on the back of the gauge. just connect it to a 12v switched supply.
i don't have the diagrams to hand or i'd tell you pin numbers and suchlike.
let me know if it's still clear as mud and i'll see what else i can find out for you
tom
thanks matey, i'll have a look tommoro!
does anyone know which wires to connect on the back (pin no.s)?
