Bike engines weight and power output
carpmart - 24/9/07 at 08:44 AM
Hi Chaps
Has anyone got a comprehensive list of bike engine weights and power outputs?
Particularly interested in earlier blade engines up to 918cc and ZX9 carb engine.
I need to use one in a 900cc class I will be racing in next year and am keen to see if there is a significant difference.
Also, which is the more available and lower cost as this will input to my decision as well.
Harvey
the_fbi - 24/9/07 at 09:22 AM
I can't find it currently, but there is something like fireblades.org.uk which lists all the engines, engine numbers, weights, bhp/torque etc.
Edit: Found it.
http://www.honda-fireblades.co.uk/specifications.html
[Edited on 24/9/07 by the_fbi]
smart51 - 24/9/07 at 09:23 AM
can't help you with a list or with blades but my 98 R1 engine was weighed at 60kg complete but without carbs. It makes 152 BHP on the dyno in my car with a home made airbox, big air filter and straight through exhaust.
I bet other people will be along here soon to add to the list.
mackei23b - 24/9/07 at 09:26 AM
zx9r carb 140bhp, going to apporx 150 with Dynojet and sausage air filter, weight, not sure, I'd say approx 60 kg, but this is a guess, I'ts a bit heavier that the fireblades.
Also have a look at http://www.westfield-world.com/enginespecs_bike.html
Ian
ChrisGamlin - 24/9/07 at 12:11 PM
From dyno runs Ive seen posted in various forums, the ZX9 seems to average about ~10bhp more than the carbed blade. They are geared significantly lower though so if you need high top speed and are using a prop driven diff (as opposed to chain drive), then gearing on the ZX9 may be an issue
As for weight, the blade is ~55-60kgs, the ZX9 isn't much different I dont think, maybe a couple of kgs heavier.
Toady1 - 27/9/07 at 05:14 PM
id say mine (late 954 blade) complete was around the 60kgs figure, I lifted it into my chassis on my own put it that way!
carpmart - 27/9/07 at 09:22 PM
Guys - thanks for all you input on this, its been very helpful and informative!
