Afternoon All
Does anyone happen to know the size of the circlip that secures the clutch arm on the R1? None of my circlip selection fit.
TC
Do you not still have the one I left on it?
I went through about a hundred at work to find one that fitted!
I'd thought that you couldn't find one? I must have dreamt that conversation. I haven't even checked to see that it's not there!
Ooops. Oh well, one less thing to buy!
[Edited on 29/7/08 by TimC]
No, I bought three that were meant to be the right size and none of them fitted, so I brought a box of them home (reason I didn't do it straight
away was because it was a box of hundreds that were all unsorted!) and so it took an age to find one!
[Edited on 30/7/08 by worX]
I got one from the local motor factors having put the verniers on it. Cant remember the size off hand though
Hi Tim
I had to take it off tonight to move the clutch arm around one spline so I measured it, and the circlip Ive got is 10mm internal diameter.
HTH
Chris
