i noticed a few people have like convertable roofs.hoods for there cars.
where do i get one from and what else will i need?
eg screen etc
[Edited on 8/6/10 by jossey]
Soft bits for sevens on the web do all sorts
Kev
I believe MK sell them for the Indy they may fit
If you want to drive with a roof on you'll need a screen and demisters. If you've got a screen you just need a sewing machine, some waterproof material (lots on Ebay) and some time. Quite a nice little project.... I still haven't used mine with the car moving though. And it's worth thinking about fitting easy-out zips otherwise getting in / out is an exercise in flexibility in the extreme.
If you just want something to keep the wet off when it's stood up, you can get a "car cap" from Halfords and cut n shut to fit,
assuming you've got a sewing machine.
For something that you can use when going along, as Ben says, you will need a screen and (probably) demisting, though maybe not if you don't use
side screens.
Soft Bits for Sevens will do bespoke but it won't be cheap.
Other than Surrey Dave, Piddy also did a very neat half hood using sail type material; I copied ideas from them and made a Caterham hood into a half
hood - got a Caterham screen so it had the front poppers already in the right place, but as standard would no way fit my car.
Simon
As always, i will try to be funny and make a useless post.
Sorry
But you could adapt one of these.
It even has side screens.
Have a look in my Photo Archive cost less than £20 can travel 80+ no problem keeps the wet off
I've a hood on my MK and have not got demisters. I have never had an issue as plenty of air still gets in through the gaps which avoids misting up. I also passed MOT without so much as a mention of any heater/demister.
Sorry
Or, you could ask for help from Top Gear presenters
ye great thanks :O)
ill give building one a go.
just need my roll cage now then :O)
Doubt it locost is much smaller in width??
