Have spent the last week on leave from work in the garage trying to have a push at getting finished.
Engine's now fully plumbed with water and petrol, suspension has been apart (again) to fit the tubular shims from Gaz (top men....) in the shocks
like I should have been told in the first place - also reset rear camber (again) to reduce negative a bit. Fitted and wired front indicators on the
wings and connected up rear light clusters. Fitted instruments in dash panel - very cool - white faced ETBs in polished carbon panel.
Had booked an auto electrician to come and do the dash wiring today, but after sounding really positive he tried to work out the column switches and
relay pack for two hours then apologised but said that he didn't think that he could do it ! He was very apologetic and didn't charge for
the time he had spent, which was good as I subsequently had to undo or re-do most of what he had done ! Anyhow, bought a multimeter and got stuck in,
and with the exception of a few silly questions (see other posts) I think I'll be OK. In fact, if I can get my alternator and ignition circuit
questions answered I might even be able to try and fire it up tomorrow - now that really would be progress !!
Simon
where are you based? maybe one of the members couls come round and help with the electrics?
Am based about 10 miles due west of Cambridge just inside Bedfordshire. Will be in the garage most of tomorrow and Sunday afternoon - anyone with
sparky fingers very, very welcome !! If you are free and fancy coming over then please U2U for my contact details.
Simon
Simon
Which column/ switchgear are you using? and also which wiring loom?
Hi there
Sierra column, though the wiring colours and connector numbers mostly don't match the instructions that came with the loom or the relay pack -
both original Viento items from old Luego.
To be honest, now I've gotten stuck in with a proper meter I'm getting along OK. Have sorted out the column and loom connections for the
lighting relays and will work on the indicators/hazards and engine wiring tomorrow. No heater, wipers or washers, so lots rolled up with nothing to do
Thanks again
Simon
Might be worth doing a search on here for wiring instructions for the Sierra switches. CHECK your switches for the part number as they are wired up differently.
I been doing my wiring lately and this is what I've worked out so far.
LINKY
Probably won't help but you never know!
Regards
Rich
[Edited on 22/9/07 by RichardK]
