As the title says realy? Being looking through the Blue book online and im even more confused!
Our car is road legal 2000cc with no windscreen, what class would this be in?
Pictures in our archive.
Also will our rollcage be ok?
Could any one post a list of all the basic things I will need
Paperwork
Car
clothing
Mookaloid is the man to talk too
Way down here we run a road going kit car class and just by looking at your pics i would say thats were you would go
Roll bar doesn't look legal (i'm guessing but no diagonal brace & curious if its CDS steel)
Paperwork
Car
clothing
Yep FDMC
Was thinking of the harewood hillclimb championship. Being to watch for the last two years, Pluss it is not too far from us. About an hours drive if that.
i have been to harewood today too its only 10 mins away for me i will have my indy on rd soon and want to compeat there isnt a kitcar class at
harewood its modyfied production and kitcar class upto 1700 for me with me having a gsxr1000 power but with it not having a reverse i may have to go
to super libra class which is anything goes so upagainst 1400 and 1600 hyabusa powerd things and radicals.
one guy i spoke to had a sylvia striker with hyabusa and no reverse and said he was in modified production but he shouldnt realy be there as he had no
revers but he said they some times will over look the bike powered kitcars
but u are running a zetec by looks so no problem there there was a real fast westy duratec in blue that was very tidy
Hi,
We're about to do exactly the same thing, start our first season in Sprints and Hillclimbs (although being based in Norfolk I suspect it will be
mainly Sprints) also in a Velocity.
THe only thing we have done to the roadgoing car is
Fit a plumbed in fire extinguisher, you have to carry one anyway so I thought it was worth doing properly, cost about £120.
Fit a battery cut off switch, not a requirement as the ignition switch would suffice but ours is actually a bit awkward to get to so I thought, in a
panic if you REALLY need to kill the engine, a big red pull switch would be easier, cost about £20.
Fit a 5 point, 3 inch harness on the drivers side, cost around £150 (and having witnessed the almighty shunt in the CSCC Magnificent Sevens race at
Snetterton last Saturday I think that's money well spent).
Bouought a helmet obviously, cost around £300 (if I'm reading the Blue Book correctly Type A helmets won't be OK after this year, A/FR will
be OK, worth bearing in mind if you're about to buy one).
The other thing we have had done is have an extension on the roll bar. No 2 son who is competing in the same car is just over six feet and with a
helmet on his head was protecting the roll bar, not the other way round, cost around £200.
Only thing left to get is a decent set of (1A) tyres, was thinking of Toyo Proxes CF1 if anyone has any opinions on them.
[Edited on 12/4/09 by norfolkluego]
Harewood is a good championship, mookaloid used to run in that with a pinto indy i remember.
Tootal - you will deffo be in the sports libre class with a bike engine kit car at harewood. as you rightly say you will be up against radicals etc.
auto66 will let you in the road going kit car class with a bike engine. club is based in scarboro, they run at elvington and at oliies mount. great
hillclimb
We are running a 2.0L Zetec
Oops, sorry for the size of that picture.
There's also a decent book on Sprinting and Hillclimbing which is worth reading.
http://www.veloce.co.uk/shop/products/productDetail.php?prod_id=V4103&prod_group=Cars%20Vans%20&%20Trucks&
Hi
Class would normally be 2B, over 1700cc Road going Kits and space framed cars.
You don't need to have a fire extinguisher fitted if you don't want one.
4 point belts are fine, looking at your pictures you have them already?
Roll bar looks fine to me too.
You may want to check re the lack of a windscreen, round here (North West) most sprints insist on them - some hillclimbs don't - so check in your
area.
Likewise for Tyres, you'll probably need to be on MSA list 1A's if you're not allready.
If you're near to Harewood why not pop along and ask one of the Scruitineers to give it the once over after the events kicks off - not known them
bite anybody recently..
Did the first few years driving the car to events, only came home on the back of an RAC truck once (it's a road car, you can peel the numbers off
and get it out of the paddock..) - which is something to consider if it's only local stuff and you don't have a car transporter trailer
handy
Not sure I agree with the windscreen regs.
Blue Book I.48 Windscreens are mandatory for all closed vehicle but free for open vehicles.
Fire extinguishers, a bit vague but I think all car must carry one, hand held is OK, plumbed is recommended, that's how I read it, could be
wrong.
Fire extinguishers, a bit vague but I think all car must carry one, hand held is OK, plumbed is recommended, that's how I read it, could be wrong.
The AEMC regs (that's what we'll be doing) state
All glass and its raising and lowering mechanism must remain as originally fitted
(except windscreen, which may be replaced with one of laminated glass if not fitted as standard). Aero screens are allowed.
As my car was built and SVA'd without a windscreen I assume I'm OK with that.
Interestingly they do allow 1b tyres but that would then bring into play C(c) 31-35 or 36 (which does enforce the diagonal on the roll bar), I read
that as - don't need a diagonal if running on 1a.
I'll qualify all of the above with 'I think'.
Hi
Good stuff that sorts out the windscreen nicely - just be worth keeping your eye on other event regs once you start venturing out and about a bit - as
you will
The roll bar should be determined by the class you're in - if they allow 1B tyres for class 2B then your roll bar should be fine - but I would
check that with a friendly scruitineer just to be 100%.
For example if you were running in Mod prod then a diagonal strut is a must even if you were running on bog standard road rubber.
This causes fun if somebody turns up on 1B's round here, for a 'Road Going' class - as theoretically they should then be moved to Mod
Prod but the car safety spec may not be up to it.
[Edited on 13/4/09 by JimSpencer]
if you wanted to go sprinting or hillclimbing in a road going class your roll bar is fine as long as your head is 50 mm below the top of your bar.
I run in the wscc speed series in a road going modified class.....car engines up to 1800cc and bike engines up to 1150cc you have to run a windscreen
or aero screen if you choose aero as most do it has to be at least 75mm above the scuttle top we also run list 1 b tyres,however on the day at the
meetings we are reclassified into none road going class and are put in with the slick shod running cars
if you wanted to do the harewood champ you have 2 choices with your car (2l zetec)
1 put a windscreen on it and run in road going with list 1a tyres
2 take the screen off and get the car msa logbooked and run on slicks (non roadgoing)
Just thought I'd wade in...
I've been competing in Class 5 at Harewood (Roadgoing kit and non-ferrous chassied cars over 1700cc) for about 10 years...
Happy to answer any queries - but its all in the Harewood regs and blue book too.
In short: you need a windscreen, wipers, washers and an MOT and tax. You need list 1a tyres. Your rollbar is fine - its NOT to MSA or FIA spec and its
not 50mm below th ebar - its 50mm between the bar and the forward chassis point (so - the base of the scuttle then). Doesnt matter - its recomended
not mandatory atm.
Hope this helps a bit.
Nik
