heres a pic of the map i used
4-2-1 manifold and mk can with cat
also using a 3.62 diff with 195/50/15 tyres
speedo healer v4 set at
4
0
0
hope that helps someone
Not being funny but i guess it would help ZX12 engined owners to know what you used the map for. It it an SVA map or a power map??
Being in the SVA section - its an emissions map??
[Edited on 1/3/09 by Paul TigerB6]
I would guess that the clue is at the bottom of the screen in the photo. There appears to be a bit of a hint there
Well spotted - didnt see that hiding down there.
Originally posted by Richard Quinn
I would guess that the clue is at the bottom of the screen in the photo. There appears to be a bit of a hint there![]()
Hello,
i have just seen the map you had.
we tried to design a map in a Power Commander test center, and when we gave values under -10 around 2000-2500 rpm, the engine was runing so bad that
we were afraid to break it.
my engine is 2001 with westfield cat exhaust.
this is why i choose to change my ECu and place a Lambda sensor ( that will be done this week)
Gerardo
