hi all
what will i need to do to make it sva proof will have a filter out through top of bonnet
any tips on what you all done to sort it
cheers
colin
just put some nice trim around the edge of the hole to make it look nice.
will the chrome filter be a problem its self
cheers
colin
RamAir foam filter on wire frame, hole trimmed. Not questioned at SVA
Just been SVA'd today. I edged the hole with rubber edging and applied self narrow adhesive draught excluder to the top and bottom edge of the filter. (try B & Q or similar for this. Available in brown and white and sometimes called E foam as it is E shaped) Passed no probs. The tester did ask if the edge was less than 2.5mm below the rubber. The rubber will certainly fall off some time though.
do you have a picture of the filter
