The day started out bad, but got better!!
We previously had a problem with the twin dellortos where one or two barrels would flood causing a misfire and fuel to poor out of the choke. We
'cured' this by replacing the needles a few weeks back.
However what happens as soon as we start it up to roll into the test lane.....fuel all over the floor and a misfire.The tester (David), as nice as he
was said the test could not continue, however after some pursuasion he allowed us 10 minutes outside to try and sort it. Luckily after pulling the top
off the carb and messing with the float we seemed to cure it and it held for the rest of the test.
Failures were:
Brake flexis rubbing on suspension
gear knob radii
no anti slip on the brake pedal
a fuel pipe to the carb needs securing
loose engine mounting bolt
loose lock nut on top wishbone
Also had advisories on rear brake inbalance (left to right) and a minor coolant leak at the inlet manifold.
All in all not bad
Easy fix's compared to some!
Soon be sorted and on the road
Just gonna say, would he not let you sort them out as he spotted them?
should be on the road just in time for Summer
Nice one
At least you can go back and show him that you have improved the fuel problem as well.
All easily fixed.
Not a bad result really.
They will bend the rule, but they wont break them.
To be fair, the guys I had for my SVA were brilliant. I failed twice before passing the SVA.
Dont worry... Its all part of the journey.
Wow. Easy remedial work for the re-test!! Good fail........
Carbs, sounds like too much pressure 2-3 lbs is all they need, too much pressure will push the fuel past the needle and seat.
Put a new filter on the fuel line you may be getting small dirt particles from and new tank and build dust.
Agreed ^^^ on fuel perssure. Also check that the float isn't sinking.
The rest are easy fixes (no none-slip is a schoolboy error, as are loose nuts). Dave did mine last year and he was good and fair (but failed me). You
probably used up all your "good will" by flooding his nice clean floor.
Soon be back for a pass.
adrian
quote:I once had an issue with either a Weber or Dellorto (had lots of carbs on grassers in the past so it's not me being particularly thick and not remembering what make I had) with a tiny split/hole in the float resulting in the float sinking. Worth checking!
The rest are easy fixes (no none-slip is a schoolboy error, as are loose nuts). Dave did mine last year and he was good and fair (but failed me). You probably used up all your "good will" by flooding his nice clean floor.![]()
adrian
Did they look at the Mushroom being pinned to the hub, as I am undecided whether I should do this
The secondary fixing of the mushroom seems to be a Beverly trait! If you intend taking yours to Beverly, drill, tap and use a grub screw or similar!
