seatbelt bolts
RickRick - 12/5/09 at 08:46 PM
I've just recived some 7/16th unf bolts ordered online for my seatbelts, described as grade S supplied marked L with 3 lines equaly spaced. I belive mr sva wont like these. does anyone have a table of bolt strength using letters for imperial bolts
coozer - 12/5/09 at 08:51 PM
Go down the srappy.. I got mine out the front of a Ford Ka. Stamped correctly and correct 7/16th thread.
RickRick - 12/5/09 at 08:52 PM
i need 2.5 inch long bolts to get my belts up above the seat line not sure i'll get them from a scrappy, and i bought these specificaly for the S marking just need to confirm L is lower strength than S before i kick off
matt_claydon - 12/5/09 at 09:05 PM
Bolts used in structural areas should be of grade 8.8 or better. Such bolts will be marked 8.8 or 12.9 on the hexagonal head, however, cap-head bolts or 7/16" ( 11mm ) UNF seat belt anchorage bolts (with an anodised finish) not marked in this way may normally be considered to be of equivalent strength. Bolts should be M8 or larger.
f1ngers - 12/5/09 at 10:04 PM
Are you sure thats grade S and not grade 5? The 3 equally spaced lines denote grade 5 which is equivalent to 8.8. The L is probably the manufacturers mark.
This chart shows grade 5 and 8.8 and their specifications.
BenB - 12/5/09 at 10:04 PM
Silly thing is racing spec harnesses use 8mm 12.9 bolts. A 7/16" bolt is 11mm so unless it's made from chocolate it'll be strong enough even if less than 8.8 grade....
blakep82 - 12/5/09 at 10:51 PM
it'll be equivalent strength. another one of those rules people think it MUST be 7/16 UNF, and it doesn't have to be
MikeCapon - 13/5/09 at 07:03 AM
Anodised???? Who wrote this? Am I right in thinking this is the SVA or IVA requirement. AFAIK anodising is a surface treatment that is applied exclusively to aluminium.
BenB - 13/5/09 at 10:28 AM
Yes, presumably they're getting confused between anodizing and electroplating. Anodizing is increasing the thickness of the oxide layer (and sometimes staining it) to improve resistance to rust. Obviously it is only a good idea for some metals- increasing the oxide layer on the outside of a steel workpiece would be a bad thing!!! IIRC it's done on metals like Ali, titanium, zinc, magnesium, stuff like that....
