I have just bought some VDO gauges from Scootz (cheers scootz exactly as described) and I am a bit worried they won't pass the IVA test due to
the bezels. The bezels can best be described as square edges with a small radius on them.
Will these go through the IVA outside of the exempt area? If not does anyone have any suggestions?
Edited to ask if it's possible to get the bezels off and replace?
[Edited on 27/2/12 by Irony]
A couple of them could be fitted in the exempt are behind the wheel and then fit them in recesses on the dash so the test sphere cant reach them?
How much do the bezels project? as anything less than 3.2mm only needs to be blunted.
[Edited on 27/2/12 by loggyboy]
The bezels project about 5mm on the smaller gauges. I didn't really want to recess them to be honest. Surely there must be away of getting them off?
