IVA passed today, first time. Feeling pleased with myself tonight!
My test was at Nottingham with Andy and I think he was very reasonable with his approach and advice.
There were a few problems along the way:
Radius on the headlights - the screw that holds the lens on. A nut cover fixed this.
Alternator cable needed a tie wrap.
Rear number plate didn't have 45degree angle of visibility - this one came as a surprise, I had put the number plate between the fog and reverse
lights but as they are 60mm deep it obscured the plate. The plate light was flipped and problem sorted.
Emissions were out, easily fixed with a fuel adjustment as I had my laptop and it was the non cat test so not difficult to achieve 3%co.
The brakes surprised me, I expected to struggle on the rear brake effort but it was fine and the fronts locked first no problem.
Andy didn't like the lock wire the bias bar and asked me to add a lock nut which I had no problem with. One rear brake was lazy on the handbrake
but just passed.
Headlight aim was good too which was another surprise as I had only set using some lines on a piece of card in the garage.
And lastly the noise test, it was tested at 5500 which was higher than I expected (max power 6400rpm) but just passed at 98db. I had measure 96 at
4800 using a good noise meter so I didn't really expect a problem.
After all the long days, late nights, early starts and stressing I'm now feeling a bit tired.
Brilliant day though and one that I will long remember! hard to believe I started this in 2005 and planned to be finished in 2 years, misjudged that
slightly. Unfortunately I will be revisiting the test centre in the near future as I left my build folder behind - must have been too excited!
Would love to upload a few photos but I cant get the archive to accept them so will try again tomorrow.
Dan
Congratulations
best keep off the roads for a bit though - salt and ice - never a good combination
I think the dvla will keep me off the road, 6 weeks and still no v55/5!
Does that online form order system ever work? I’ve tried several times over the past few weeks but nothing has come.
Pictures pictures pictures!
Good work!
For reference, my v55 came through in about a week.
I also got one sent to a friend at his address as backup....
Huge congratulations.
I can well imagine how pleased you are, well done.
Congratulations
When my MK Indy passed it's SVA some years ago I remember a rather large dose of good feelings!
I look out my work window (Basingstoke, Hampshire) and it's pi55ing it down. Don't let that put you off though - I drove my car over a couple of winters. Wrapped up warm and taking care it's good - the roads are quieter and the thrill of driving a car you've built really is worth it!
Nice one!
Must feel good after all the stress about the weather.
Registration form delivery from the on-line order is usually quite quick. I'd order another one and see what happens.
I feel very relieved to get that hurdle out of the way!
Ive asked a couple of friends to order the form too but nothing has arrived yet. Hopefully i will get it soon.
Will try again to upload a few photos tonight.
Dan
Same message on the photo uploads, unnsuported file type. Never had that message before using this camera.
Well done on the pass!!! Bet you can't wait to drive it. As others have said, be careful, even if the road is just a little damp you can easily
spin off with just a small touch on the throttle.
by the way......all the best folk pass 1st time
Congratulations, well done for a first time pass.
I'll be on the look out for you when the good weather comes. Maybe see if there are a few others around the Lincoln area who want to meet up in
the spring
Well done !!!
Big pat on the back for you .... great to hear !
Managed to get a few photos uploaded, taken a couple of days before final IVA prep:
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
Why did they test the RPM at a much higher level?
well done mate, great feeling.. I never took my cars off the road over winter. a couple of us used to go out rain , snow or shine of a Sunday morning -- before the kids came a long and I let the car go.... make the most of it and take it easy.
Looks great - what thickness alu did you use for your dash? I want to make one very similar but not sure how thick it needs to be...?
Documents all sent off to the DVLA now, after waiting weeks I got three V55/5 forms arrive in 2 days! I've also had the VIN letter arrive again
so presumably my dealer stamped reply never landed on the correct desk, I sent it recorded delivery so I know it arrived somewhere!
Good old IVA and make the rules up as you go along!! Well done on the pass though!
