hello all
im using the 4age on dellortos. now i would like some sugestions on blanking off the injector holes. i was thinking of making up some tophats out of
aluminium??
any tips
I will have this job to do as well in the near future, I was just going to turn some aluminium plugs as a push fit to the injector holes and put a
rubber washer underneath and a bit of sealant to stop any air getting in. Top hat sounds like a good idea, as it would make it easier to get them out
should you ever want to. I'd be interested to see your solution in any case.
Adam
ally top hats and a dab of loctite
Alloy top hats with an O ring groove cut into them, use an O ring and forget the loctite.
Mick
My injectors were block off with large grub screws. This is how RAW do it. Just be careful not to get any metal in engine when tapping holes!!
Ben.
the carbs are already bolted on now so dont wanna go cutting threads. its bit of a bitch to get all the carbs set up off, top hat with o ring sounds
good to me. cheers guys appreciate the comments
Rob
