Last week i bought 5 meter of normal fuel hose, it's a clear sort, just the normal kind of hose.
Yesterday a friend askes me if this was the righr one for SVA specifications, are there any special specifications for the fuel hose i would like to
use ?
Thanks,
Marco
I'mm 99.9% sure it has to me marked for use for fuel on the side so the stuff you have bought will not pass SVA. The stuff you want is black 8mm
fuel tubing marked as such.
Anyone please correct me if i'm wrong.
Originally posted by donut
I'mm 99.9% sure it has to me marked for use for fuel on the side so the stuff you have bought will not pass SVA. The stuff you want is black 8mm fuel tubing marked as such.
i made a picture of the side of the fuelhose.
Marco
sounds for me like a fail..
its more for water and pumps etc..
Tks
well, the man at the parts shop sold me the wrong hose.
Where can i buy the correct fuel hose online ?
Thanks for the advice.
Marco
Can't you take it back and get him to change it for the correct stuff?
if i can change it for flexible copper line will that be a good alternative ?
Marco
Marco
If this is for your main fuel line, tank to engine, copper is just fine. Just make sure that any hoses connecting from it to tank, and carb are the
correct type hose, "ie" marked as such. atb Chippy.
Reman, just beat me to it
[Edited on 7-6-06 by Chippy]
Clear hose is a fail as it becomes brittle when exposed to petrol.
You can buy the rubber stuff at most places like Halfords etc.
Pat...
Pat...
