Already for second SVA Test tomorrow at Mitcham, just 5 things to get re-tested and the tester told us that when we get the rear brake up to scratch it will probabbly fail the front to rear bais equation, so we have fitted a adjustable valve in the engine bay that he said we can adjust and then lock in the correct position on the test rig. Lets hope it does not rain this time.
Best of luck
We should see you on the road in May then
Good Luck!!!
Good luck
