Power steering will still work without the power of course, as that is an essential safety feature. However, the unassisted steering is fairly heavy
and presumably this is caused not only by the fact that the racks are usually quite 'quick' but also because of the mechanism itself causing
some drag.
Does anyone happen to know if a power steering rack can be modified so that it is usable without the power? especially from a legal point of view?
Thanks in anticipation
John
The ratios are usually differnt in asssisted racks...
And if there is any evidence that it was once a PAS rack... it will fail an MOT because "if its fitted it has to work" and ergo... a pas
rack with no hydraulic feed is not cosher!
Originally posted by tegwin
And if there is any evidence that it was once a PAS rack... it will fail an MOT because "if its fitted it has to work" and ergo... a pas rack with no hydraulic feed is not cosher!
Saxo's and peugeot 106's have electric PAS pumps - Could use that to power it
If you were to do this then i suppose you'd have to use some form of lubrication other than the fluid used in PAS, which i believe is quite highly pressurised, it's still under pressure when the engine is stopped hence the heavy steering, if you were to release the pressure then the rack should be easier to turn, I THINK !
quite a few cars are now using electric PAS pumps , vauxhall being one of them .
the problem as i see it , is that you have seals in there to prevent fluid loss(hence making the rack work) , which if oil gets in or you havent got
rid of all the oil - itll lock up when you dont really want to .
take all the gubbins out , and decide for yourself if teh rack will operate smoothly etc .
May we enquire as to why you need to convert one ?
Some racks have external hydraulic rams which can be removed.
Next thing to be removed is the valve unit.
Darren
Won't fail MOT if the power steering pump is not fitted.
The Sierra ratio is about 2.7 , the power steering rack is 2.4.
To use a power steering rack as a quick rack take off the flexi pipes, connect the fixed tubes on the rack together with one bit of flexi pipe,
before connecting both pipes together add some power steering fluid, keeps things lubricated.
But the later Astra's has the PAS electric pump mounted to the bulkhead complete with resorvoir .
The AC compressor has an electric clutch so that the compressor doesn't turn when not needed . Pity it's so bulky
Miata people use it a lot, as a sort of quickrack. They remove the R&P out of it and remove the seals, put it back together and blank off the PAS
fluid ports.
Here is a guide:
Miata PAS removal
The valve assembly in PAS racks contains a torsion bar which operates the valve, under manual operation this will be subject to a lot of force, and
will therefore add unwanted lost motion to the steering.
This has been covered dozens of times in the past.
[Edited on 30/5/09 by MikeRJ]
Most MNR's were supplied with PAS racks ( if ordered from them ) up until recently when they've gone over to Escorts.
Mine has one fitted, has been modified by MNR to fit.
It doesn't have any pipes on it or anything else connected - the ratio of a PAS rack gives a quick rack.
It works fine - nice and light and passed SVA recently with it.
I retro fitted power steering to our Saxo. Bought pump, rack, pipes and loom all off e-bay for £60.
We used a Saxo pump on our 6R4 with a Cavalier power rack.
The only thing to be careful of with the Saxo pump is that it uses a feed tied in with the alternator so that it doesn't run until the alternator
is charging. Otherwise I suppose you might struggle to turn the engine over adequately while that pump is spinning.
Electric columns are good, but need a strong dash rail....
Thanks for all the replies, it would seem that the ideal solution would be for me to use the rack as is and obtain an electic pump. Power steering
would be useful in this application so that's what I will go with.
John
Tiny bit of exaggeration there, do you think?
No I don't. Look back through the archives if you can be bothered, it really has been asked many times before.
To use a power steering rack as a quick rack take off the flexi pipes, connect the fixed tubes on the rack together with one bit of flexi pipe, before connecting both pipes together add some power steering fluid, keeps things lubricated.
I did, and found many different opinions. Are you in a bad mood or something?
No, quite a good mood as it happens. Just pointing out the facts.
Right, back on track for a mo!
I looked at doing this many many years ago (well, 1997) on my self built RWD pug 205 rally car which used sierra struts and rack.
I thought I could use the sierra pas rack as a quickrack with no fluid connections and the piston machined off the rack bar.....
It certainly did work, BUT I didn't like the look of the torsion valve, and there was no apparent way of dismantling it to make it rigid. It
doesn't twist much at all, but it bothered me so I just fitted a sierra quickrack kit into a normal manual rack and used that (they are only
cheap anyway)
There you go, a paractical answer, if not one that will solve your query!
I would go for an electric pump. I know of a LOT of autograssers using either those, or electric assisted columns like the fiat and corsa ones, on the
class 6 huge power front drive class cars with very tight diffs.
Keeping on track ..... anyone any idea how you make sure when using an electric pump that the power steering isn't incredibly light?
I like heavy steering, means I can 'feel' the road. I just worry if you fit random bits together you may get too much assistance.
You may not like what Mikerj has to say, but he is correct that de-powering a power rack is not a good idea. The torsion shaft is a skinny little
spring that is designed to twist allowing the spool to work smoothly. It is also used as an emergency manual connection.
It is in no way designed for the extra load of constant manual operation. Torsion shafts are usually all of 0.25" thick VS the 0.75-1" tube
that is normally used for steering shafts.
You will also get slop because the torsion shaft will flex before turning the wheel as it is designed to.
Custom racks really aren't all that much money and you will get a faster ratio so you aren't flapping your arms like an idiot while
racing.
Cheers.
Cory
Just one other alternative for you. On the works 6R4 we ran a standard PAS pump off the front diff driven with a poly-V belt. Worked well (except for
parking
) and, as far as I am aware, passed MOTs.
