Stopping the steering flapping
speedyxjs - 20/6/09 at 06:47 PM
What can i use to hold the steering column in place. Iv been looking at rose joints but none i have looked at say what the internal diameter is (my steering shaft is 16mm).
blakep82 - 20/6/09 at 06:51 PM
http://www.mcgillmotorsports.co.uk/index.php?act=viewProd&productId=20
these ones are 16mm hole
[Edited on 20/6/09 by blakep82]
speedyxjs - 20/6/09 at 07:10 PM
Cheers. Do you think it will be a problem if the joint cant be removed without having to cut the shaft as i need to weld it to the uj?
omega0684 - 20/6/09 at 07:27 PM
what you want is one of THESE
speedyxjs - 20/6/09 at 07:31 PM
The bore size is 1".
andyd - 20/6/09 at 07:34 PM
I'm sure he meant one of THESE
omega0684 - 20/6/09 at 07:37 PM
a thank you
speedyxjs - 20/6/09 at 07:40 PM
Oh right. Didnt see them on the site
