Hi all -
I ned to get my front toe and camber set up. Unfortunately with the very low clearance of the Dax front cycle wings, my local garage and ATS
can't do this as they have the laser alignment gear that hangs over the wheels, and there isn't enough clearance to fit it.
Does anyone know anywhere local(ish) to Godalming/Haslemere area that might have the kit to do this?
I have about 1cm clearance between the tyre and the cycle wing...
Nick
Can't recomend anywere local to you.
But after setting my Indy up myself using a large set suqare, tape measure, spirit level and precise floor markings I took it to my tried and trusted
tyre place (Micheldever Tyres) where I know the operators and had it checked.
It was surpisingly accurate...
Camber L = -1.47 deg
Camber R = -1.44 deg
Toe L = 0.08 deg
Toe R = 0.07 deg
(rack/wheel centred with less than 1mm difference in track rod length)
Worth investing the time at home IMHO.
^^ agree with Nick, not difficult if you take you time, but you do need a flat surface to do it on... I would do as nick set it up then get it
confirmed by a professional system. After that you know you can set up the car however you want...
I found the book:
Competition Car Suspension: A Practical Handbook (Hardcover)
by Allan Staniforth
Linky
Very helpful..
Dan
Forgot to mention - I used this book as a guide...
Unfortunately, living in the Surrey Hills, the chance of finding a flat and level surface is remote
I already did a DIY alignment in my level(-ish) garage but wanted to get it confirmed and checked by someone with the proper kit.
I'll see if there is anyone a bit further afield...
Nick
Probably too far away, but as above Micheldever Tyres between Basingstoke and Winchester have the right kit. I have no clearance on my front arches,
but their alignment sensors hang from the rim itself rather then the tyre so it's not an issue.
The guys there are also keen petrol heads themselves and sympathetic to non-production car requirements.
Google for Micheldever Tyre and Auto Services.
Id try Micheldever but be aware they do get VERY busy! Worth phoning to be honest.....
Try
http://www.alignmycar.co.uk/
to find a local alignment centre.
Hope this helps
A big thumbs-up for racecardoctor.com
Excellent service and base din Lewis, near Brighton.
