I want to fit an in-line pressure switch for the stop lights,any clues anyone?.
I'm using the MK floor up pedals and fitting a normal electrical switch is a bit awkward there.
I'm sure in-line pressure switches have been used,but cant seem to find what i'm looking for.
I got mine and a four way adaptor from merlin motorsport.
Have plumbed it in at the front split point where the pipes go to each FU tube brackets. Scutter
Bob,got mine from scrappie-old VW golf -fitted t-piece to rear pipes and screwed switch into t-piece-dont forget you will need metric switch to fit sierra fittings,Mike.
Thanks Dan/mike
I think the T-piece and switch from VW is the way to go,probably cheaper than MM as well(even new)
I think there is a pic of this in the links at sevenbuild.com
A very informative indy build archive.
And where at the back of the car is it?
Thanks,
James
Thanks,
James
Yep thats the one James
Turns out merlinmotorsort.co.uk were less than i thought,just over £10 all in door to door.
Well i'm glad thats sorted
James
Nice to see some of your selective bits on your car are cheap,thanks for the mini advice.
Switch was under bonnet if i remember correctly but i cant remember what it was fitted to -easy to get though.As for Vinces 7build-great site but lets have some new stuff Vince!!-so i can copy it!!!Mike.
