How did others do this ?
Sticky back fasteners on the axle itself ? ?
James
I don't think sticky fastners are acceptable for SVA
A piece of rubber pad behind the pipe and a cable tie around the axle to secure the pipe
Mike
Originally posted by Mikey G
A piece of rubber pad behind the pipe and a cable tie around the axle to secure the pipe![]()
Mike
Flexi's where needed and lined P-Clips where not less than 300mm apart.
Yep P clips on mine.
Tack weld 3mm setscrews at intervals then put on P clips and fasten with nut.
Larger 6mm setscrew welded on side of banjo for the brake line T piece.
Welded mini bracket on top holding flexy pipe for movement.
I welded some steel strips on to the axle and put some plastic pipe around the brake pipe and then bent the strip around that.
Uncle Henry welded strips on my axle when he made it, just for fixing the brake pipes
Same on my Capri axle. No rubber involved.
