Hi all,
wondered if anyone can help on my brake upgrade quandry?
Im running Powerlites at present on Cortina uprights which was an upgrade from my std M16's running green stuff. If im honest i hardly felt any
difference.
Im now in the market to upgrade again.
My car has 262bhp, weighs around 590kgs and spend 80% of my time on track.
My first port of call is the Midilites with disc upgrade to possibly the vented version but have been warned they are heavy discs abd will have an
small adverse effect on brake performance.
So do i go with Midilites or are the HiSpec units any better and do i stick with solids or go vented?
My budget is 4-5 hundred quid by the way before anyone gets carried away
[Edited on 9/10/13 by laptoprob]
What size wheels and tyres are you running? Big wheels and tyres is a great deal more leverage on the brakes, on 13" wheels I cannot get my
brakes hot on the track no matter how hard I try so will replace the vented discs at some point.
If you just find the pedal hard change the pivot point on the pedal
[Edited on 9/10/13 by mark chandler]
Used AP's would be my shout
Originally posted by mark chandler
What size wheels and tyres are you running? Big wheels and tyres is a great deal more leverage on the brakes, on 13" wheels I cannot get my brakes hot on the track no matter how hard I try so will replace the vented discs at some point.
Sorry should have put 15" wheels.
Pedal is fine just brakes arent man enough for any confidence at the min and if i remember right your running quite a bit less weight than i am?.
What pads are you running now in your current calipers?
With me sat in it maybe 500kg, I run slicks on the track so the brakes really get hammered, still need to lose the vented discs for singles.
Mintex 1144 pads on the front and green stuff on the rear sierra calipers, You could try different pads before splashing out on a new setup.
Regards Mark
hi I went from power lights on my race car to raceleda what a difference in my eyes wildwood are crap they flex to much never had a good feel with
them
I have same uprights as you and solid disc with raceleda with hawk pads all I can say is fantastic glad I did it
I think mnr sell these callipers says that on there web site
I run powerlites on my vortx with polymatrix pads. The stopping performance is great with no brake fade.
At the Blyton Park track I can just touch the 120mph mark round Lancaster and down the straight before having to hit the brakes hard to go around the
wiggler chicane. The brakes perform flawlessly each time
i run the wilwood dynalites on the radical. they are the basic radical brakes (not the upgraded floating disc type) and the braking performance is id a different league to any 7 ive had including the caterham. ive had powerlited,hispec,ford wtc but this thing is a different animal!
hi I went from power lights on my race car to raceleda what a difference in my eyes wildwood are crap they flex to much never had a good feel with them
I think mnr sell these callipers says that on there web sitequote:
Seen loads of posts on forums about his problem too. Never thought about Raceleda, i may have a look at these cheers.
Regards Markquote:
Cheers Mark, think it will have to be the solid disc. Thanks for the info, what calipers are you using?
At the Blyton Park track I can just touch the 120mph mark round Lancaster and down the straight before having to hit the brakes hard to go around the wiggler chicane. The brakes perform flawlessly each timequote:
Blyton is always the big test for my brakes as it is small and has a big succession of corners. The polymatrix pad maybe a starting point for me here as ive seen other people talk them up on other forums,cheers.
laptoprob - 10/10/13 at 06:48 AMquote:
cheers Dan, i know the brakes are great on your cars but again your running nearly 200kgs lighter than me so will make the difference.![]()
rodgling - 10/10/13 at 07:01 AMWhat are you trying to improve about your brakes?
I have powerlites on an 800 kg car (with me in it) and think they are v good. But I am running 1144 pads, not the Wilwood pads which everyone on here says are poo (I've not tried them). Try pads first as a cheap/easy improvement?
Benzo - 10/10/13 at 07:05 AMquote:
Agreed! Put some good pads in 1st front and rear. Mintex 1144 or ds2500's would be what I would recommend!
[Edited on 10/10/13 by Benzo]
amalyos - 10/10/13 at 07:23 AMI run powerlites on my RGB car, and their fine. The biggest difference I made was changing the pads this season. I went over to 'Polymatrix A' pads, very happy with them.
adithorp - 10/10/13 at 08:18 AMI'd have a bit of a read through the RGB forum before considering Hi-Specs. Several people have had problems with them. Two guys I go touring with have had them and both had trouble with them binding.
I'd try different pads first. 1144's have been good for me in my Powerlights even on Alpine decents. Though I'm now at the point around Blyton, where I'm only finding any more time by pushing the braking points and starting to get fade (for those that don't know it, it's hard on brakes).
If you're getting fade though after that then you need either bigger or vented discs (or cooling ducts?). Changing calipers won't help a lot with heat. There's not a lot of chance of going bigger on the discs under 13"s.
mazie - 10/10/13 at 08:30 AMI run powerlites , solid discs and 1144's on a 700kg car with me in it and they are pretty awesome, never fade and the pedal feel is superb.
rdodger - 10/10/13 at 08:32 AMI have Midilite's with 260mm vented discs. Powerlite on the back. Car is approx. 600kg. Fiat MC.
I started with smart pads. They took at least a couple of laps to work at all then were very good. Scarey on the road.
I now have 1144 all round. The pedal feels much better and the brake feel is really consistent. Fade? No chance!
edsco - 10/10/13 at 09:08 AMI run Powerlites with Poly A pads on my race car in RGB series. I cant flaw them. The combo is very effective.
My only issue i have had this season with them was when racing on the GP circuit at Donington earlier this year. Doing the longer circuit with the addition of two hairpns in quick succession meant i cooked the brakes big time. On talking with other racers later, it turned out everyone, or the large majority, had experienced brake fade on the hairpins too which consisted of a large range of caliper makes.
I am running vented discs on front and still got brake fade, but I think the issue was more to do with lack of positive ducted airflow for cooling.
I was told that Poly A pads if allowed to get too low can also be susceptible to brake fade due to there not being enough pad material to absorb or rather help dissipate the heat. However, worn pads were not the cause of my one and only specific issue.
My personal opinion Wilwoods give a good positive feel when combine with the right pads. I ran Wilwoods with Mintex pads on my Spire several years ago and they felt numb, not particularly grippy or grabby, so swapped pads and things improved immensely.
Horzes for courses i guess.
laptoprob - 10/10/13 at 10:12 AMquote:
Will have a look Adi at the forums etc. My brakes went twice at Blyton when i was there last with you but the pads were at the end of their life etc and yes Blyton is a pig on brakes for sure.
Im after a better brake all round really as i dont have confidence in them at present, they dont scrub speed fast enough for me. Im going to try the Polymax A in them as im off to Oulton next Friday and now dont have the time to change the whole setup etc.
On another note my brakes have never faded at Blyton with Willwood pads in and my wheels are 15"![]()
rodgling - 10/10/13 at 10:20 AMHmm. Looking at this: http://www.wilwood.com/PDF/Flyers/fl227.pdf why would anyone use any Wilwood compound other than A?
jeffw - 10/10/13 at 10:26 AMI had Powerlite with solid discs and was melting the disc so went to Midlites with vented. I am running Hawk DTC30 pads which are very good but you can use 1144s which are much better than the Willwood pads.
adithorp - 10/10/13 at 11:22 AMquote:
In never had any fade from mine with the Wilwood SmartPads during the shorttime I had them fitted either... I didn't have any usefull braking either though!
Davey D - 10/10/13 at 11:29 AMquote:
Yeah its the Polymatrix A compund that i use. There came recommended to me from Andy at ABPerformance. With slicks on i can brake that hard that my body is pressing hard into my harness straps. Loads of feel to them too. The odd time i pushed just that little too much and locked the wheels you can feather the brakes, and re apply with full power again
coyoteboy - 10/10/13 at 12:28 PMDisc diameter is one of the key drivers of the apparent braking force - how do everyones rotor sizes compare - that would be my first question. Given the same piston areas all the calipers should give roughly the same stopping results, give or take a few percent. The difference will come when you change the torque they can provide. This will increase stopping force available but increase the likelihood of fade. IF you're nowhere near a fade limit, just up the rotor diam?
loggyboy - 10/10/13 at 12:57 PMquote:
Originally posted by coyoteboy
Disc diameter is one of the key drivers of the apparent braking force - how do everyones rotor sizes compare - that would be my first question. Given the same piston areas all the calipers should give roughly the same stopping results, give or take a few percent. The difference will come when you change the torque they can provide. This will increase stopping force available but increase the likelihood of fade. If you're nowhere near a fade limit, just up the rotor diam?
Surely a larger disc would also disipate heat quicker so balance out the increased forces applied?
pekwah1 - 10/10/13 at 02:31 PMif you can find Carbotech brake pads for your calipers, they're supposed to be amazing!!
Not half expensive though....
PhillipM - 10/10/13 at 03:24 PMThey are, XP8's blow anything Wilwood offers away. The Wilwood compounds are pretty old though, so to be expected.
Powerlites are fine on lighter cars, anything much over the 700kg mark and you should be switching up to Midilites though, that's generally where all these rumours of excessive flex come from - people running the smallest, cheapest caliper on cars much heavier than they were designed for.
unijacko67 - 10/10/13 at 04:12 PMI had the Ferodo 2500 (FRP3108H) in at Blyton ppc day and although I wasn't as fast as you chaps I did have a tad more weight to stop and didn't have any brake fade issues. I cant compare as I haven't used any other types, but seem to stop ok.
Neadles - 12/10/13 at 06:46 AMI have HI Spec calipers with green stuff pads and solid disc, as this is how I bought it and after my first year with the car on track there not great at all. I thinking mainly because i have never rated the EBC pads, but they do flex I thinkink as I have about 1.5-2 mm pad thickness defference accross them as I have been warned by a few people this might happen. I like to brake hard and late and its just not doing it for me and at Blyton I have cooked the brakes everytime which is what dictates my sessions length. So the seup will be changing! I've always been a fan of AP with Dixcel carbon pads but don't think they would cost effective.
I am thinking of Powerlights with 1144 pads.
Rob if you want to try try my calipers as my car is away for the winter let me know. (I have Mk2 escort uprights which I beleve are the same as cortina ones?)
laptoprob - 12/10/13 at 08:15 AMquote:
Thats a very kind offer mate but ive decided to go Polymatrix A race pads for next weeks visit to Oulton and test the water.(literally if its raining).
If they perform ok i may stick with the Powerlites short term in view of changing to Midilites with solid disc.
I like AP too but dont have AP money![]()
StevieB - 12/10/13 at 08:29 AMquote:
Hi all,
Im running Powerlites at present on Cortina uprights which was an upgrade from my std M16's running green stuff. If im honest i hardly felt any difference.
My first port of call is the Midilites with disc upgrade to possibly the vented version but have been warned they are heavy discs abd will have an small adverse effect on brake performance.
My budget is 4-5 hundred quid by the way before anyone gets carried away![]()
Do you have a bias valve to play with? Might be worth giving one a go before abondoning the powerlites and putting a load more money in (but give me a shout if you do because I want some on my westfield)
If you can adjus the bias, you might find a better balance that suits your needs rather than forking out a heap of money to then possibly have a similar problem.
jeffw - 12/10/13 at 09:12 AMquote:
The reason for your cooked brakes is a lack of cooling. Remember brakes will run hotter in a Fury/Phoenix than a Seven so you either have to run cooling ducts or vented discs. The BEC Furys get away with it due to low weight but a CEC enclosed car needs the next brakes up...
Neadles - 12/10/13 at 11:20 AMquote:
I appreciate that Jeff, but it is a Furyblade so is light, the bite is not great and I cannot break as late as most. i thought about over heating and ducting but I'm still not happy with the feel of the brakes. The MC's are right and the balance bar seems to be just about right.
laptoprob - 12/10/13 at 12:14 PMquote:
Hi all,
I did think about the fact i may have needed a bias in there but the brakes hardly ever lock up to be fair so i think it about right anyway. It may lock an inside wheel when braking downhill at speed but that pretty normal with weight tranfer etc.
Ill keep you posted on the Powerlite Steve if i decide to let them go![]()
PhillipM - 12/10/13 at 01:02 PMBin the Greenstuffs.
We have Hispecs on the rear of the racer and have no issues with caliper flex, the pads wear absolutely square even down to a shadow on the backing plate. Might be worth checking they're mounted perfectly square to the discs.
