I'm trying to find a pair of rear Sierra aluminium bearing carriers that work with the Tripod (push in) drive shafts. Anyone that knows where to get them?
These might be ford pattern not sure.
http://www.shop.drdracingproducts.com/Alloy-brake-brackets-brak-brks.htm
Be careful, all the aluminium bearing carriers I've looked at are for the larger bearings (bolt on shafts).
Marc at MNR is looking into making them for the smaller bearings, contact him direct.
I've got 2 spare sets Delphi bk693 if that's what your after
Regards
mark
Ask Berrisford, it looks like they do two types.
http://www.berrisford.co.uk
Thanks for you suggestions!
I actually e-mailed Berrisford and DRD Racing a couple of days ago and Berrisford has replies that their carriers only fit the Lobro drive shafts.
Still waiting for a reply from DRD. I'll let you know how it goes in case someone else needs the info.
I've spoken to Chris at MNR earlier and he mentioned that the might do a Tripod version later on.
I'll keep looking then!
