Has anyone got dimensions/drawings of the Fiat Cinquecento/Seicento steering rack?
My racks in the UK and I'm not there till Feb!!
I've got one in the workshop, I'll try and run a tape measure over it in the next day or so
Google came up with this. Don't know if it's any good? I'm guessing RHD would be the same dimensions.
•Operating Mode: Manual
•Driver Position: for left-hand drive vehicles
•Overall Length: 914 mm
•Mounting bores distance: 240 mm
•Input shaft height: 57 mm
•Input shaft connecting type: Splined
•Number of splines on input shaft: 17
•Input Shaft Diameter: 14 mm
•Manufacturer Restriction: TRW
•Axle Joint Length: 166 mm
•Axle Joint Thread Size: M12x1,5
That's brilliant, many thanks.
Never found that myself! Maybe it's this French service provider I use!
