Hi
Does anyone know if i can get data regarding suspension bush dimensions, i need some for my kit but only have the sizes, no idea of donor, they were
already fitted when i got it, manufacturer of kit no longer exist.
For info
O/D of bush 25mm ? that's the I/D of tube it goes in, has to be tight fit so slightly larger.
I/D of crush tube 12mm
total length 40mm
I've contacted some manufacturers, waiting for replies.
Thanks in advance
Hal
They normally imperial ain't they??
interested to know about this.. I cant find any to replace mine with .
robin hood 2b with gbs wishbone conversion.
I used Trumph herald poly bushes on my 7, and would say they are about the same dimensions you have quoted
Hi Hal, these dimensions sound very similar to the Cortina ones I'm using, got them from Flo-Flex if that helps
http://www.floflex.co.uk/product_info.php?cPath=23_40_89&products_id=302
[img]http://
[/img]
[img]
[/img]
[img]
[/img]
