Hi,
In the Haynes book (see image), it lists the ID and OD of the stainless bushings, but it doesn't give the length. I've made a couple of at
36mm (2 x the 18mm shown for each half of the bush). I think I'm missing something!
Anyone tell me what size the collar should be?
Thanks, Geedle.
[img]https://drive.google.com/open?id=1BzwnAdxSk2tBMoGs5MEwxg-ymCmBxCLk[/img]
You've assumed the top hat bushes meet back to back - they don't!
The crush tube needs to be as long as the width of the tube your bushes go into, plus 2x the depth of the stepped section, plus a little bit (to avoid
binding).
Alternatively you can consider they need to be the same length as the distance between the inside faces of the suspension bracket!
Yup - that's where I went wrong. So the inner tube should be clamped tight in the jaws of the bracket when the bolt goes through? Is that what
I'm aiming for?
Thanks.
Originally posted by geedle
Yup - that's where I went wrong. So the inner tube should be clamped tight in the jaws of the bracket when the bolt goes through? Is that what I'm aiming for?
Thanks.
That makes a lot of sense. My brackets are already on, but still good information. Much appreciated - thanks.
Remember using wishbones with a narrower eye than the mounting brackets gives a small amount of castor adjustment using shims( I used stainless repair washers)
Had not considered that. How my under do I need to make the collars? A couple of mm?
I put a thin stainless penny washer either side between the bush and bracket, reduces friction nicely when greased up
My Luego has brackets approx 10mm wider than the arms.
That's quite a bit of adjustment. OK - thanks for that. Just as well I checked, otherwise I'd have been doing it twice!
I've been thinking (and reading) about this more. I was planning to build my wishbones with threaded adjusters as per the Saturn manual. That should give me the caster adjustment I need shouldn't it? Or am I missing something...
