Have trawled the search and seen much talk of tapers and redrills.
Can anyone confirm if you can use a Maxi or astra bottom ball joint unmodified with a sierra front hub???
cheers
Pete
I used Maxi balljoints, Quinten Hazel QSJ602S, they fitted fine. In fact the whole front end went together perfectly as per the book.
And it sort of makes you wonder why MK have to drill the Sierra uprights for the Maxi ball joint and you didn't, are there two types of Maxi
joints?
Chris
I believe that TVR used the sierra uprights on the griff and chimeara, i wonder what bottom ball joint they used?
maxi ball joints fit ok with cortina hubs, as book but if you use sierra hubs and maxi balljoints the bottom taper needs reaming to 15 degrees to fit properly
Does the vauxhall astra ones need any redrilling?
or are there others that dont ??
pete
Sorry my mistake! I guess I should read the whole question before jumping in. I'm off back to the garage now where it's dark.
pete
