Small wheels big brakes
stressy - 11/2/06 at 08:18 AM
Nice and easy.....
Is anyone using, or does anybody know if you can use 13" wheels with sierra rear discs and calipers?
Specifically is anybody using RS type 4 spokes?
Cheers.
flak monkey - 11/2/06 at 08:37 AM
IIRC I dont think you can. 13" alloys have a much smaller internal diamter than 13" steel wheels.
piddy - 11/2/06 at 09:37 AM
I think it depends what car there from.
I have some 13" wheels from a cortina that were planned to be used to push the car around the garage during the building stage, but they wouldnt fit the back or front of my car. ( discs all round)
However on my last car I had 13" four spoke Capri wheels and they fitted the front Ok. The rear were drums.
I therefore think that if they fitted the front then they probably would fit the rear as well.
I would think that you will be ok with the Capri four spokes they have a much wider offset.
The ones fitted to the Fiesta Super sport will not fit!
I dont know, but I wouldn't think the Escort ones would fit.
I hope this helps.
[Edited on 11/2/06 by piddy]
donut - 11/2/06 at 09:57 AM
Talk to MAC#1, they have a set of 13" wheels on one of their cars.
speed8 - 11/2/06 at 10:00 AM
Yep. I'm putting 13" alloys on mine with Sierra rears and Wilwood fronts.
Talk to Mac#1 as there are a couple of little mods needing done.
What offset are your wheels because some of the ones I looked at won't fit. I'm needing ET35-38.
chriscook - 11/2/06 at 10:47 AM
I've got 13" alloy wheels over sierra rear calipers with hi-spec fronts. Mine are ET24 but i'll have 10mm spacers on the rear but thats only to fill the arches and nothing to do with clearing the caliper.
eddymcclements - 11/2/06 at 12:41 PM
I have 13" KN Minators over Sierra calipers and the only mod I had to make was to bend the handbrake arms on the calipers slightly to clear the rims.
Eddy
