Can anybody tell me what the distance is between the outside of the mountingplates where the sierra component must be fitted from leftside to
rightside of the car as the lower wishbones is horizontal??.
Would be glad if I don't have to cut the wishbones having the right distance.
I make it 1382mm on my car (from my CAD) between the left and right bearing carrier to upright interfaces. You've got plenty of movement in the
driveshafts so dont worry if your's is a bit different to that.
Liam
Originally posted by Liam
I make it 1382mm on my car (from my CAD) between the left and right bearing carrier to upright interfaces. You've got plenty of movement in the driveshafts so dont worry if your's is a bit different to that.
Liam
