Brass Brake 4-way question.
TimC - 13/3/07 at 06:03 PM
Evening folks
Quick question for you. Most brake installations will use a 4-way brake 't-piece' as no doubt intended i.e input front, brake light sender back and left and right being left and right.
My brake set-up (and mounting position means that this is difficult to acheive. if I were to say input from right, have sender at front, left as left and right as back would I have any brake distribution issues or will a closed loop hydraulic circuit cope with the direction changes?
Hope that this makes some sense.... I appreciate that it aint easy to follow.
TC
MikeRJ - 13/3/07 at 06:20 PM
No problem at all, there is no correct or incorrect port to use for any given function. It's simply a small hydraulic manifold, the pressure at each port will be exactly the same.
TimC - 14/3/07 at 08:03 AM
Cheers both - I love it when a plan comes together.
