Brakes
Jos Fury - 28/10/07 at 12:17 PM
I am looking for an upgrade for my M16 callipers ( non vented discs standard pads ).
Breaking is okay but some weight reduction and some more feel would be welcome. I use large drums in the rear which I want to keep ( there are two sizes forgot which size though .. ).
Also I would not like to disturb the balance too much.
Hi-spec - Willwood - Alcon - Outlaw ??
I really do not know of course like to keep it low cost
RazMan - 28/10/07 at 03:45 PM
Wilwood Dynalites would probably be my choice - RD sell a kit which will go straight on your uprights. If you also swap to alloy hubs at the same time you will get quite a weight saving too.
[Edited on 28-10-07 by RazMan]
britishtrident - 29/10/07 at 09:53 AM
Your feel problem is more to do with the master cylinder, you need either a smaller bore master cylinder or more pedal leverage ot both.
Jos Fury - 30/10/07 at 06:45 AM
thanks for your advice.
yesterday somebody visited me and left a set of wilwoods for me to try them out for fitting etc
thanks Harm
[Edited on 30/10/07 by Jos Fury]
