Im looking to get a sierra 4x4 so i can get a 3.62 lsd and rear disk brake setup.
Is it only the xr4x4 with the parts i need or would a 4x4 estate have the bits?
Thanks in advance
Mike
All the 4x4s apart from the cossie have the same diff and brakes - as far as I know. as I understand it the only flash thing about the xr4x4 is the
bodykit.
we broke a 4x4 ghia estate, it has LSD and rear disc brakes.
Hi
Dont forgety that you can get a LSD from a 4x4 Granny but the drive flanges are 5 studded. I think thats the only difference, and i think you can swap
the drive flanges for 4 studded sierra 4x4 drive flanges
Well thats what im doing/have done......!
4x4 gls sierra is another donor.
2wd abs sierra's have rear discs, but not lsd's. beware!
there are different size difs, sierra 4x4's are mostly 7", some granada's and cosworths are 7.5" and cosworth motortsport difs are
9"
Ned.
Thanks for the help. I think i will stick with a sierra 4x4 so i get the 7" LSD as thats one of the main bits i need as im going R1 engine so not
to worred about whats under the bonnet.
Thanks again
Mike
