hello all
i m after an after market racing style steering wheel that is a direct replacement for the sierra one (3 spoke), ie bolt off sierra and bolt on new
(no messing about)
can anyone help with links etc ?
cheers
Finlay
you won't get one. you'll need an adaptor boss to suit the bolt pattern of the aftermarket wheel.
don't waste your money on a mountney m-range boss. pay the £3 extra and get a momo one.
tom
If you have access to a lathe you can do what I did..... I used the standard sierra boss - so the steering lock works & the horn connections work - but cut it out of the wheel & turned it to mate with a custom aluminium boss which the wheel (a "ripspeed" item from the discount tray in halfords) then bolts to. All very satisfactory & suitably locost given the initial proviso...
