My battery is in the passenger footwell but at the moment i have no foot rest or cover for it. Is this likely to cause a problem for IVA?
I would say yes is wohld raise concern.
Not so much concern if it was under the bonnet where it was not going to get messed with / touched.
At the very least it should have insulated terminal covers.
In my eyes, roll it, what's to stop the passenger and you getting plastered in battery acid?
The battery strap![]()
that stops it moving, doesnt stop it leaking!
My inclination would be to site it in the footwell only as a last resort. As said ^^ battery acid is wicked stuff.
Are you sure there's no room in the engine compartment?
Mine squeezes in between the side chassis rails via a removable side panel and sits on the bottom chassis rail helping lower the centre of
gravity.
Alt. mount it in the boot - helps with weight distribution even if the cabling does cost.
HTH.
Cheers, Pewe
Im a about to inspect in the region of 4000 batterys in the next three months......and take it from me 1
batts do not work on thier side and two no matter what the manufacturer tells you all batts have the potenial to leak no matter how much they
cost.
3 the contents of this magic box has some of the most aggresive chemicals that love to eat and burn what ever they come into contact with.
At least get a marine battery box to contain it.
And mod the footwell to isolate you from the block.
Heeds these words and stay safe........
Thanks for all the replys.
Would a sandwich box be suitable locost option to cover the battery?
Does this help? Battery is secured with the remains of a deep fat frier and covered with a piece of ali secured with velcro.
Will look brilliant too!![]()
My battery is in the footwell.
I made an ali panel that I riveted between the tunnel cover and inner cover and the battery bracket.
SVA was cool with this and gives the passenger a footrest.
HTH,
James
put it in the boot. you know it makes sense
I would equally have concerns about being painted in sulphuric acid.
Still amused me when my latest bike battery came with a little bottle of the stuff in the standard royal mail post! How is that allowable?
