i have a sierra diesel for sale non runner but every thing else is good cam belt has broke. £150 ono low millage 76000 diff ideal for BEC
I'll give you £100 for the diff if its a 3.38.
Hows that sound?
Fight you for it
If its a 3.38 and coozer doesnt have it I'll have second dibs!
but if its a 1.8D then it'll probably only have a 3.62
how can i tell without taking casing off
it is a turbo diesel
There should be a tag with numbers stamped on it through one of the back cover bolts. Can you see it?
i will look tommorrow bit rushed atm
also got tax till 07 09
and if it's a 3.14 then I'll have it please?!
sorry to rain on your prade
if its got a cam belt - its a 1.8
if its got a turbo - its a 1.8
fair enough its still for sale
just to confirm the diff ratio - whats the axle code on the vin plate ?
vin plate says u
diff plate
8 3bg 1c 362
a 2d09 1 356
3.62
you can still by it if you want lol
its still a good donor for someone - all they need is an engine.....
it'll have a type 9 box
(with a long input shaft but the bellhousing is longer too - I think)
I guess it will also have rear drum brakes, with push-in drive shafts
it has m8
