Prices include P&P unless stated. Can bring small bits to Stoneleigh as required.
Image deleted by owner
A selection of trim bits and pieces.
Large terminal covers work well to cover the top balljoint at the front as well as batt terminals. £3
Gland seals are good for covering track rod extensions. £3
Small red batt cover sold
Pinto auxiliary belt, brand new. £5
Pinto cam pulley (also have a bolt and key in one of the other pics to suit), clean and ready to fit, complete with back plate. £5+P&P
Type 9 gear lever - Sold
Fiesta engine mounts, commonly used in locosts. £8
Bosch pinto dizzy cap. Used but in good condition. £5
Pinto 88deg thermostat. Fitted to mine for about 500miles. Sold
Complete set of pinto HT leads inc coil lead. 8mm high performance silicone. £10
Set of almost new APR6FS pinto spark plugs. Been run for a few mins to try and diagnose my ignition probs. £10
Type 9 gearbox layshafts. 1 brand new, other 2 used but no measurable wear. £10 for new one
I also have a complete gear set for a type 9 which is in good condition. Free to collect
Pinto oil pressure switch - Sold
Pinto water temp sender £3
Pinto valve springs. Standard, low mileage. £10
Belkin Serial 9 pin male to female extension type cable suitable for megasquirt. 2m long, brand new. £5
Dash 3 braided hose fittings. All M10x1 thread. 2 male convex seat and 2 female concave seat. SVA OK. £5
Pinto fuel pump drive pin £2
Accelerator cable adaptor for twin cable applications. Block fits on top of accelerator pedal to convert to twin cables. Sold
Set of new lay gear bearings for type 9 box. £10
Seal for speedo output on T9. £3
Pair of cortina M16 calipers. Seen better days to be honest and one is seized. Could be useful to rebuild or as an exchange set for someone to avoid
the surcharge? Free to collect before they go in the skip
Various type 9 parts. Let me know what you need and I'll see if I have it. Big stuff is collection only, but small bits I can post. All free
3?! sierra rear hubs for drum brakes. Free to collect
Pair of front indicators on SVA extensions, passed with these fitted to my car, Matt also passed with these at Norwich. £10
That 1st pic and you avatar look very phalic.
Pat...
Does your box have a cover plate for the flywheel? the one I've got doesn't have one.
Also need the bolts with it if you do
Also I'll take your speedo sender cover if it's still there
U2U
type 9 parts
Also need the bolts with it if you do![]()
Can I have the little red battery terminal cover please.
Oh yeah lol. Forgot to give that to you yesterday! I'll stick it in the post when I get a minute!
I can pick it up when I drop the sync round.
Bump
Can bring odd bits to stoneleigh if needed.
got my bits today thanks David.
Originally posted by omega 24 v6
got my bits today thanks David.![]()
