anyone want to build a trailer?
I have four brand new Alco axles, two are a pair to build a four wheeler, 75 inches between brake back plates, rated at 1000 kg each, fully braked
with reverse antilocks, all galvanised.
One is for a single axle trailer, rated at 1300 kg, bigger brakes than the other two,reverse antilocks, all gavanised, 74 inch between brake back
plates.
one that has been widened and welded,
bit rusty but never used, would need widening further to take a car.
Looking for 250 pounds for the mached pair.
125 pounds for the single 74 incher
85 for the welded one.
I also have an Alco anti sway hitch with brakes and hanbrake gear. 120 pounds.
based near Selby East Yorkshire.
Regards Denis.
I may be interested in the axles, what all is with the 75" pair reagrding brake shoes, cables drums/hubs, standard trailer PCD?
would it be possible to cobble the 2x1000 and the 1300 together to make a 6 wheeler? Could the hitch cope with all those brakes to operate?
Have replied via u2u to both posters .
Thanks Denis.
[Edited on 1/11/09 by kipper]
I have just sent some pics of axles to my archive.
Denis.
I have four brand new Alco axles, two are a pair to build a four wheeler, 75 inches between brake back plates, rated at 1000 kg each, fully braked with reverse antilocks, all galvanised.
One is for a single axle trailer, rated at 1300 kg, bigger brakes than the other two,reverse antilocks, all gavanised, 74 inch between brake back plates.
Regards Denis.
